Voxson Portable Autoradio TANGA
Posted: Tue Jul 27, 2010 9:21 pm
by justix
HI, here something my dad use to own, it's the Voxson TANGA, a little beauty of design, one of the very first portable Car radio available on the market at that time, and with an Home module too!!! designed by R. Bonetto produced in 1970
Definitely ahead of his time..
I did my best to match the only good photo available on the net, no tech drawings as such but it is very very close.
I have some artifacts on the model, I hope to bring a finished render asap!
Original render 1st 2000x2000 at 4000samples 23.4Megasamples average render time 24 minutes but it was well cooked in 14 minutes!
the second is 1024x1024 a little close up (and you can see some fk up in exporting from Rhino) but at 2000samples took 3 minutes!!
Actually I had problems in making a good transparent plastic material, I need it for the front mask all the attempts failed ;(
Re: Voxson Portable Autoradio TANGA
Posted: Wed Jul 28, 2010 7:32 am
by tomas_p
Hi justix.
Nice work.
Can you tell me what is the count of triangles?
thanks
Posted: Wed Jul 28, 2010 8:48 am
by mib2berlin
Nice moddel and design, the table could have a different color for more contrast and it is to dark.
I've always the same problem, not realy calibrated monitor.
Cheers mib
Posted: Wed Jul 28, 2010 9:40 am
by justix
tomas_p wrote:Hi justix.
Nice work.
thanks
Triangles count is 113393
About the darkness of the picture I have your same problem, I will uses a different filter in the forthcoming ones if none.
I'm actually struggle with something that I lost in my mind, if I zoom in with the wheel to adjust the camera should Octane just render what I see on the screen? because here is what I got instead when saving the file, that is weird or am I missing something?
Posted: Wed Jul 28, 2010 10:54 am
by mib2berlin
Hm, your saved picture is what you have in the viewport, i tested it again here.
Mib
Posted: Wed Jul 28, 2010 1:48 pm
by justix
mib2berlin wrote:Hm, your saved picture is what you have in the viewport, i tested it again here.
Mib
Not really, I mean, if I hit the full screen I see what you see on the screen picture but when saved the model is far from what I see on the screen, like if the camera is resetting the FOV on saving
Posted: Wed Jul 28, 2010 5:46 pm
by tomas_p
Hi justix.
Thanks for triangles count.
I have withal one question: is applied an bumping in your scene, or only simple roughtnes?
Posted: Wed Jul 28, 2010 8:13 pm
by justix
Yes there is a bump map to reproduce the rough surface : )
Posted: Mon Aug 02, 2010 12:36 pm
by 3Angels
Mib
The problem is that when the size, 2000 x 2000 in your case, is larger than your monitor size you have to use CTRL drag to see the whole image. Best to first setup your scene in a small image size and when happy, then change to a larger format and render.
