GeForce GTX Titan
Posted: Wed Feb 13, 2013 3:41 pm
Looks like the card really does exist. Many specs here but found the below interesting for octane :
http://www.brightsideofnews.com/news/20 ... -7990.aspx
Performance - Faster or slower than a Dual-GPU GTX 690? HD 7990?
If you decide to use this card for GPGPU, for example password cracking, this card should be able to beat the K20 and K20X without breaking a sweat. The company castrated the Double Precision, and you can expect great Single Precision performance (2,688 CUDA cores time 875 MHz should result in around 4.5 TFLOPS SP from a single chip). Double-precision follows the Kepler tradition of 1/24 Single Precision performance. Yes, 4.7 TFLOPS SP and 196 GFLOPS DP, nicely protecting Tesla K20/K20X and the upcoming Quadro K6000 products.
The chip commands pixel fillrate of 49 GPixel/s and texel fillrate of 196 GTexel/s (once more, Texel fillrate is identical to FP64 Double Precision), while 384-bit at six billion transfers per second was enough for amazingly high 288.4GB/s.
Preliminary results show that in 3DMark Fire Strike (Extreme), GTX Titan scores 4870. According to our own testing, this would put the part some 500 points (10%) behind two GeForce GTX 680s in SLI mode. Given that single GTX 680 achieves around 3000 points, almost 1900 points fewer than GTX Titan. Bear in mind this is still not enough to beat a single GeForce GTX 690.
