Octane Render Close-Up tests...
Posted: Thu Jan 10, 2013 8:25 pm
by cadvis
Hello All,
Another Octane shoots I've made. Hope you'll like them.
Re: Octane Render Close-Up tests...
Posted: Fri Jan 11, 2013 2:00 pm
by nehale
What are the render specs on these?
Posted: Fri Jan 11, 2013 3:03 pm
by MaTtY631990
Nice and simple :) . Note, in image 1 you seem to have a smoothing issue with glass.
Posted: Fri Jan 11, 2013 6:28 pm
by cadvis
Thanks for your comments.
Render settings (Attachment)
Window 7 64bit
Nvidia GTX 570
Regards the glass: I've noticed it but unfortunately I don't know how to import from blender perfectly smoothed object. It looks right in blender though. This happens only with glass material - when other material is applied than the mesh is perfectly smooth.
Posted: Fri Jan 11, 2013 6:48 pm
by kavorka
is the smoothing option turned off for the glass material?
Posted: Fri Jan 11, 2013 8:56 pm
by cadvis
Wow.. so simple. Yes you were right ~kavorka! The 'smooth' option was switched off....
Thanks for pointing that out. I never thought that there is such an option there.
I'm new with Octane but that is not an explanation.
Much appreciated.
Posted: Fri Jan 11, 2013 9:10 pm
by kavorka
cadvis wrote:Wow.. so simple. Yes you were right ~kavorka! The 'smooth' option was switched off....
Much appreciated.
Not a problem. Be careful, it is turned on by default, but some of the online materials have them switched off.
Posted: Fri Jan 11, 2013 9:38 pm
by cadvis
Thanks ~kavorka. This knowledge will help me a lot.
