Page 1 of 2
[Req] Render hidden geometry
Posted: Mon Dec 10, 2012 9:21 am
by suvakas
Hey Karba,
Could you please add a way to render hidden geometry?
It could either be a new checkbox or use standard "Render Hidden Geometry" setting under Common tab.
This would be very useful for rendering out large amounts of instances or for heavy models too. Hiding stuff from view makes viewports a lot faster, but currently there is no way to include hidden models for rendering with Octane.
Suv
Re: [Req] Render hidden geometry
Posted: Mon Dec 10, 2012 12:32 pm
by face
Max hasn´t different settings for viewport and rendering visibility?
face
Posted: Mon Dec 10, 2012 1:18 pm
by suvakas
face wrote:Max hasn´t different settings for viewport and rendering visibility?
face
What do you mean?
It's not object property, but it's a renderer feature. You can find it under Common render settings.
It's very easy to implement. Octane should just ignore the hidden status of an object and render it no matter what.
From Max docs:
Renders all geometric objects in the scene, even if they are hidden.
I really hope Karba knows Max good enough to understand what I mean.
Suv
Posted: Mon Dec 10, 2012 2:11 pm
by Vanya
yes it is very useful. if you set the object properties that are useful in two.
And yes, what about the proxy? (like vray proxy) or (proxy view like a "box"). will it be?
*Very bad English
Posted: Mon Dec 10, 2012 5:31 pm
by iViz3D
+1. Not only in 3dsmax but a feature also in standalone itself.
Posted: Mon Dec 10, 2012 6:19 pm
by face
suvakas wrote:
What do you mean?
Suv
I mean, in Softimage, i can hide an object for rendering, for the viewport or both. And there it is an object property.
I think in Max it is the same. You are right, it is also a renderer option under the common render setting, but only because the renderer ( in this case MentalRay ), searches each object to this property.
It is the same with moveable proxies. It is an object property but the renderer searches each object for this property.
A render property can be the renderer options which will have the parameters under it for the max samples or the kernel type.
I was only wondering because Max haven´t the different visibilities for rendering and the viewport...
face
Posted: Mon Dec 10, 2012 10:07 pm
by suvakas
Of course there is a "Renderable" object property in Max too, but it's irrelevant for this topic.
Basically I'd like to see this kind of logic implemented:
if (node->Renderable() && !node->IsNodeHidden() || RenderHidden == true){render node}
Suv
Posted: Wed Dec 12, 2012 7:58 am
by suvakas
Karba, what do you think? Could you implement it?
Suv
Posted: Wed Dec 12, 2012 8:17 am
by Karba
suvakas wrote:Karba, what do you think? Could you implement it?
Suv
Wait for a new release
Posted: Wed Dec 12, 2012 8:22 am
by suvakas
Awesome !
Suv
