Page 1 of 2
Sala 002
Posted: Fri Nov 30, 2012 9:22 pm
by merid888
image done with 3dsmax 2009 x64, octanerender standalone 1 win64. size 2300 x 1700 px, pathtracing, maxdepth 8, maxsamples 5000, none hdri just an image background, time 2 hours, 38 minutes, using portal in windows adding a plane to the portal
regards
Re: Sala 002
Posted: Fri Nov 30, 2012 10:45 pm
by paoloverona
woow Merid, really a great emprovement!
I don't know if the yellowish color is intentional, but I think that it's not too good if you aim photorealsim.
you should have play a little bit more with the camera response or the color temperature of the light outside the windows to avoid all the yellowish color.
I've done a fast test with photoshop for comparison.
Cheers, Paolo
Re: Sala 002
Posted: Fri Nov 30, 2012 10:56 pm
by RealityFox
Hmmm well I would say that the outside is a bit too bright. Would it be possible to do an alpha scan and put in a background via photoshop or gimp? Not sure if that is the best solution but yah.
Re: Sala 002
Posted: Fri Nov 30, 2012 11:05 pm
by merid888
hi paolo, thank you, where i can found the camera response ? becouse i don't have idea what you talk about
reallyfox, do you know how create an alpha channel into photoshop ? becouse i don't know
regards :)
Re: Sala 002
Posted: Fri Nov 30, 2012 11:16 pm
by paoloverona
I attached an image where to find the camera response in Standalone, in Max you can find it under the "imager" settings (where you can set the exposure, f-stop, gamma...).
Re: Sala 002
Posted: Fri Nov 30, 2012 11:59 pm
by merid888
thank you paolo, i use that option always is afgacolor hdc 400 plus and the coloration is the result of this camera
maybe another camera, right ?
regards
Re: Sala 002
Posted: Sat Dec 01, 2012 12:09 am
by PAQUITO
Good work! That´s an scene with a lot of potential. From now on you should start working the post production. Paolo showed a good work about this. Take that in mind. Keep up the good work! :D
Re: Sala 002
Posted: Sat Dec 01, 2012 3:55 am
by merid888
thank you paquito
regards
Re: Sala 002
Posted: Sat Dec 01, 2012 5:33 am
by Populus
Awesome work! Love the natural lighting in this scene, looks very realistic. The outside environment however spoils the overall impression a bit, try change in postwork.
Re: Sala 002
Posted: Sat Dec 01, 2012 1:23 pm
by merid888
hi populus, thank you for comment, what do you mean The outside environment however spoils the overall impression a bit, ?
i need use photoshop ? that it ?
when i print int my plotter hp 800 ps 42", always i need exposure a litte bit the image becouse the plotter opaque the printing, i use paper hp glossy for my perspectives, 90 x 60 cms or 60 x 45 cm to my clients, what do you recommend ?
