Page 1 of 3
How will multiple GPUs be supported?
Posted: Sat Jan 23, 2010 5:17 am
by crbrown1
Radiance-
Just curious how will multi GPU cards in a single system work? I understand that each GPU must have a copy of the data to be rendered...but will it be possible to split portions of a single image/render between multiple GPU cards? Or will it support a single render job per GPU? Or is it some other method.
I'd like to use a 9600GT as the display card and (2) GTX 280s for rendering only.
Charlie
Re: How will multiple GPUs be supported?
Posted: Sat Jan 23, 2010 12:22 pm
by radiance
Yeah, you should be able to do that.
the multi-gpu setup will work transparently,
eg you're display denoises 2x as fast.
Radiance
Posted: Sat Jan 23, 2010 5:21 pm
by crbrown1
Thank you! Will the cards need to be in SLI (the two 280s) or not?
Charlie
Posted: Sat Jan 23, 2010 5:28 pm
by radiance
no, octane does'nt use SLI...
Radiance
Posted: Sat Jan 23, 2010 6:48 pm
by crbrown1
Thanks!! Wow you are quick!
Posted: Sun Jan 24, 2010 11:10 am
by JollyFather
A related question: When rendering an animation will there be an option to tell Octane to render a single frame per gpu? So if I have 3 boards 3 frames would render in parallel. I can even turn off my monitor while Octane is rendering (to disk?).
Regards,
JF
Posted: Sun Jan 24, 2010 11:13 am
by radiance
JollyFather wrote:A related question: When rendering an animation will there be an option to tell Octane to render a single frame per gpu? So if I have 3 boards 3 frames would render in parallel. I can even turn off my monitor while Octane is rendering (to disk?).
Regards,
JF
yes, we'll provide documentation to do so once these functionalities are completed.
Radiance
Posted: Wed Jan 27, 2010 10:29 am
by pluMmet
Just to be clear, 2 nVidia 295s will be 4x faster on a single image? Or can be used on 4 different images?
Posted: Wed Jan 27, 2010 10:55 am
by radiance
pluMmet wrote:Just to be clear, 2 nVidia 295s will be 4x faster on a single image? Or can be used on 4 different images?
yes. you can do both.
Radiance
Posted: Wed Jan 27, 2010 2:13 pm
by umax
this is my first post even if I'm around for a few days.
I just read about NVIDIA's Tesla 2070, a supercomputer disguised as a graphics card.
Is it in your project to make use of this power ?
Thanks for responding
