Page 1 of 2
3ds Max colour problem
Posted: Sat Nov 24, 2012 11:49 pm
by Jani
Hello,
I don't know whether this is a bug, or I am doing something wrong(in any case, it's not mentioned in the manual), but when I put on a diffuse colour or a texture, it is always 'whittened'( I don't even know if thats the right word). I will try to put it simply:
Diffuse colour set in the material editor
3ds Max Viewport
Colour seen in the render viewport
Octane Render render window
//NOTE// even the material editor's quick preview does bad colouring, it does however show black normally
I have tried all the common sense things such as changing the kernel, playing around with gamma, texture environment/sun&sky, you name it..
Oddly enough, when I was using the demo, this didn't happen(the demo was a bit outdated though). Also, in the standalone version the colours look normal as they should.
Help please, my deadline is coming close.
Re: 3ds Max colour problem
Posted: Sun Nov 25, 2012 8:14 am
by suvakas
Do you have Max gamma correction enabled?
Suv
Posted: Sun Nov 25, 2012 5:05 pm
by Jani
Here's a set of screens disclosed... As said previously, I don't see where the problem could be.
If I crank up the gamma, the image just gets brighter and less colour-y, if I put it down, I see more colour, but not the right colours(it looks strange anyways)
As for the settings, both of the screenshots the render settings are the same.
Posted: Sun Nov 25, 2012 8:23 pm
by Karba
Jani wrote:Here's a set of screens disclosed... As said previously, I don't see where the problem could be.
looks like some plugin licence issue.
Please try delete all folder with names insdie {...} in
C:\Users\[your username]\AppData\Roaming\Refractive Software\ (just write %appdata% at your win explorer)
Posted: Sun Nov 25, 2012 8:50 pm
by Jani
Karba thank you, that seems to have worked... :)
//EDIT//
There is another issue though, ever since I went from 3ds Max Octane Demo to FULL, I can't set the movable proxy boolean, when I right-click on an object, instead of the 'movable proxy' at the very bottom of the list I see 'Missing: 2398'. Is there a quick fix for this?
As I said, it happened straight after I got the full(paid) edition of 3ds max octane.
Posted: Sun Nov 25, 2012 9:48 pm
by Karba
Jani wrote:Karba thank you, that seems to have worked... :)
//EDIT//
How do you set movable proxy?
Posted: Sun Nov 25, 2012 10:12 pm
by Jani
Well, yes, that was what I meant, just the fact that it wasn't working for me :/
Posted: Sun Nov 25, 2012 10:24 pm
by Karba
Jani wrote:Well, yes, that was what I meant, just the fact that it wasn't working for me :/
What plugin version do you use?
Posted: Mon Nov 26, 2012 12:42 am
by Jani
OctaneRender_for_3ds_max_2013_COM_v1.0_beta_2.58f
or so does the file I downloaded say...
//EDIT// It happened when I replaced the files in the 3ds max root from this to the newest version(I also replaced the .../plugins/ file):
OctaneRender_for_3ds_max_2013_COM_v1.0_beta_3.03_demo
Posted: Mon Nov 26, 2012 1:21 am
by Karba
Jani wrote:OctaneRender_for_3ds_max_2013_COM_v1.0_beta_2.58f
2.58f doesn't support instancing.
Use RC3
