Page 1 of 2
Animation resolution
Posted: Wed Nov 21, 2012 4:37 pm
by 3form
Hi All
I am making an animation and rendering at 2400X1600 its a short fly in 50 frames @ 24FPS. When I playback the animation it says in the info its 720X480 I have checked max settings and octane settings all are 2400X1600. Is there a maximum animation size for octane? Hope someone has the answer! ;)
cheers
J
Re: Animation resolution
Posted: Wed Nov 21, 2012 7:41 pm
by Karba
3form wrote:Hi All
cheers
J
I tried 1280x720. It works fine. I don't think there is such limits.
Posted: Wed Nov 21, 2012 9:05 pm
by Newman
I rendered 2048x1024. Works fine.
Posted: Thu Nov 22, 2012 12:44 am
by JuM
there is no limitation its same with single frame render.
Posted: Thu Nov 22, 2012 5:41 am
by 3form
Thnks ill check my settings again ;)
Posted: Sun Nov 25, 2012 8:13 pm
by gueoct
I guess this depends of your output file format. What is it?
Posted: Mon Nov 26, 2012 7:59 am
by 3form
compress dvi
Posted: Tue Nov 27, 2012 8:42 pm
by 3form
Thanks for the info still no go prob have to reinstall max. My prev renders worked well must be a bug with max. :evil: :?: :!: :roll:
cheers
Posted: Tue Nov 27, 2012 9:53 pm
by suvakas
3form wrote:compress dvi
What's that?
If you mean DV, then it doesn't support resolutions greater than 720 (PAL).
Also you never ever want to render directly to compressed format. Only for previews maybe.
Render out as image sequence and do your compression later.
Suv
Posted: Wed Nov 28, 2012 6:06 am
by 3form
thnks suv ill try that :o ;)
