Fuzzy not clear
Posted: Thu Nov 15, 2012 8:51 pm
by 3form
Hi all!
I am working on exterior/interior project. Octane RC2 max 2012 gtx670. The image look pretty good in octane renderview when I save they come out all blurry. Using neatimage to clear up any noise. Does anyone have a remedy for this? Its not noise thats the issue I think it could be antialiansing filter is set to 1. I have attached a copy of the raw render
Cheers
Re: Fuzzy not clear
Posted: Thu Nov 15, 2012 10:18 pm
by paoloverona
the fact that you see a "perfect" image only in the Octaneviewport probably is due to the resizing of the viewport (you can see the difference with the real dimension of the render when you click on "port to max framebuffer); this resizing gives a sort of sharpening effect)......someone tells me if It is a bullshit :mrgreen:
What is the hotpixel removal value?
Re: Fuzzy not clear
Posted: Thu Nov 15, 2012 11:09 pm
by kavorka
try to check your aperture.
Also, What resolution are you rendering at?
maybe increase it.
Re: Fuzzy not clear
Posted: Fri Nov 16, 2012 7:11 am
by 3form
Hotpixel is 1 and aperture is 0. Ill try and render larger and shrink down.
cheers
Re: Fuzzy not clear
Posted: Fri Nov 30, 2012 11:40 am
by wisemanxxx
I like carpet model. Where did you get it.Please share.
Re: Fuzzy not clear
Posted: Fri Nov 30, 2012 6:49 pm
by A2Zen
Check the focus of the camera... and
Please check your model scale... too. If your model is too small then it will look blur even the aperture is low value (0.1)
:P
Re: Fuzzy not clear
Posted: Tue Dec 04, 2012 6:20 am
by 3form
Hi
I cant remeber where i got the carpet model could be turbosquid.
The scale is correct.
