Page 1 of 2
RC2 bugs and crashed report
Posted: Fri Nov 09, 2012 7:57 pm
by Karba
Please post here any bugs and crashed you have with RC2
In case of crash please explain what actions you did before.
Re: RC2 bugs and crashed report
Posted: Fri Nov 09, 2012 11:56 pm
by MaTtY631990
there is bug with the OctaneLight (sphere) with visability on. When this is set as a proxy it causes illumination problems. With visability off its fine. It's just this one, other light types work fine.
Posted: Sat Nov 10, 2012 1:32 am
by Karba
MaTtY631990 wrote:When this is set as a proxy it causes illumination problems.
Can you show your renders? How does it look like?
Posted: Sat Nov 10, 2012 4:43 am
by MaTtY631990
Here are the sample renders to illustrate the issue.
Posted: Sat Nov 10, 2012 6:25 am
by Karba
MaTtY631990 wrote:Here are the sample renders to illustrate the issue.
Thank you
We will fix it next week.
Posted: Sun Nov 11, 2012 9:47 pm
by Karba
I can't reproduce this issue.
What is your scene size?
Posted: Mon Nov 12, 2012 2:04 am
by MaTtY631990
The scene is set to meters and is a size 0.01. Its roughly 3 meters across just off to the left and right of camera. I have also attached this scene setup just in case. I am using 3dsmax 2011.
Posted: Mon Nov 12, 2012 2:23 am
by Karba
MaTtY631990 wrote:The scene is set to meters and is a size 0.01. Its roughly 3 meters across just off to the left and right of camera. I have also attached this scene setup just in case. I am using 3dsmax 2011.
Just tried your scene, no any light issue.
Are you sure you use RC2 version?
Posted: Mon Nov 12, 2012 2:43 am
by MaTtY631990
Yes, are using the RC2 version. I used 3dsmax 2011 64bit for this setup. As soon as open the viewport window I get result from same as render. Maybe if anyone else is using same 3dsmax version as me could post results, can confirm this.
Posted: Mon Nov 12, 2012 2:44 am
by Karba
MaTtY631990 wrote:Yes, are using the RC2 version. I used 3dsmax 2011 64bit for this setup. As soon as open the viewport window I get the issue present.
I tried all combination of movable proxy on/off, visibility on/off, no issue :?
