Managing scenes with many materials?
Posted: Sat Oct 13, 2012 6:39 pm
by Morat
I've been messing around with a couple of scenes that have many materials which has raised a question - what's the best way to manage a scene that has a lot of materials, e.g. after Sketchup export you import the obj and have a huuuuuuugely wide mesh node with a gazillion material points on it? What happens if you re-export the scene with an added material?
Is there a recommended way of dealing with this kind of complexity?
Re: Managing scenes with many materials?
Posted: Sat Oct 13, 2012 9:32 pm
by glimpse
actually it isn't =) You just have to deal with that - that's it! =) good way is to look wheather You need or not so much material.. if so, maybe there is possibility merge some mapping as material is more or less the same..- use some masks and do things like that.. but ovelAll is it going to be simple? no way! =)
so basicly You left here to prePlan Your work ahead and deal with that before problem arives =) nothing helpful, but O would start from the very begining..- asking right questions.. =) then things might change..
Posted: Sun Oct 14, 2012 7:10 am
by Morat
I thought that might be the case
I keep fairly organised with named materials and what have you already so that works for me.
Posted: Sun Oct 14, 2012 6:12 pm
by ROUBAL
Hi, Managing materials is always a problem in big scenes. I am working for a long time on a big city scene with many matrials on buildings, cars, buses, vegetation, urban props... And I also use instances in Octane to duplicate materials to add diversity on buildings and cars without adding too much geometry ! The amount of materials is actually huge ! Naming them with a proper name is very important, and instanced materials have to be renamed in Octane as instanced object/materials keep the same names as original but materials shaders may indeed be different !
