Falloff node - Simple HOWTO
niuq.cam
Very interesting Fooze. Thank you ! :D
I will also tests.
Niuq
archigrafix
Fooze
About your architectural glass material: the effect you achieve is called Fresnel reflexion, but I thought unbiased renderer like Octane were capable of this through the IOR value?
archigrafix
Nobody to reply about the fresnel reflections subject????
Surely I will make a topic about that cause it is something important to be precise with IMO
FooZe
Hi archigrafix,
Sorry for the late reply.
Yes, IOR can be used to do this. But the plus side of using a glossy material with fresnel/falloff is that it is more controllable, and does not effect the appearance of the scene through it.
This is a very good thing when using opacity to allow some rays straight though for lighting and casting shadows inside the room. At the moment due to limitations, light will still be "stopped" by the specular material, even if it has full transmittance. Hence the use of opacity to let rays straight through as if the glass was not there.
If you were to use a specular material with IOR and some opacity you would see some strange doubling up of the scene behind the glass. (one for the straight through rays from the opacity, and another from the rays that are effected by the IOR on passing though the specular material).
The glossy material with falloff controlled opacity and full reflection make for a simple, fast and easy solution.
Cheers
Chris.
Olitech
FooZe wrote:Hi archigrafix,
Cheers
Chris.
Is this still a viable workaround for the modern (2014) 2.xx versions?
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
FooZe
In the latest versions you can use the "fake shadows" option on the specular materials to "let light through" easily.
Have a go and you will see what it does. It will pay attention to the materials transmission and also the IOR in a limited way.
lukas8410
Useful explanation thanks!
// Behance: https://www.behance.net/LukaszKondek //
- Octane v3
- 1x Geforce 980 Ti , and 1x 570 GTX
Olitech
FooZe wrote:In the latest versions you can use the "fake shadows" option on the specular materials to "let light through" easily.
Hi Fooze,
I think we are talking about a Fresnel falloff in the reflection, not the refraction.
Best,
O
haffy
How do you set this up on lets say a Glossy Material for a cloth material? Is it in the Specular input?
3D Generalist.
whersmy
Haffy, for cloth I almost always use the Sheen option, Be sure to tick the BRDF GGX model.
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
