Octane import- textures fail
Posted: Sat Jun 09, 2012 7:44 pm
by larmannjan
when using the exporter (1.19) i get this when importing into Octane
- import_fail.png (6.84 KiB) Viewed 2481 times
I do not know what the problem is.
there are three object in the scene.
1.
No textures applied
2.
3.
Re: Octane import- textures fail
Posted: Sun Jun 10, 2012 11:18 am
by ROUBAL
Hi, I don't understand your problem : You say no texture applied, but your material shows a texture. Please be more precise.
Posted: Sun Jun 10, 2012 11:50 pm
by jandress
@roubal... he means object 1 has no image, object 2 has images as per attachment, object 3 has images as per attachment.
@ larmannjan... I notice that for Objects 2 & 3, roughness input is set to image, but there is no map listed in the text field. If you do not actually have a roughness map set input type to none. If you have a roughness map either it is not selected or not actually available in blender. Hope that helps.
Posted: Mon Jun 11, 2012 4:43 pm
by ROUBAL
For my own, I noticed that disabled texture slots in a material returned an error message.
