SU TO MAX - MATERIALS NOT APPEAR IN RENDER VIEWPORT
Posted: Sat May 12, 2012 11:40 pm
by eduardotama
HI. I NEW IN THE FORUM.
I HAVE A PROBLEM. WHEN I IMPORT SKETCHUP FILES IN 3DS MAX.
ALL THE MATERIALS APPEAR ON THE MATERIAL EDITOR BUT NOT IN THE OCTANE RENDER VIEWPORT. ALL THE MATERIAL ARE WHITE.
IN V RAY ALL RUNS OK.
SOME IDEAS¿
Re: SU TO MAX - MATERIALS NOT APPEAR IN RENDER VIEWPORT
Posted: Sun May 13, 2012 11:10 pm
by MaTtY631990
Have you double checked to make sure the formats are supported. (Sketchup materials > octane materials conversion).
It lists supported materials on the octane plugin tabs.
Posted: Mon May 14, 2012 1:32 am
by Karba
eduardotama wrote:HI. I NEW IN THE FORUM.
SOME IDEAS¿
What kind of materials Sketchup produces?
Is it standard materials?
Did you try to convert it by octane material converter?
Posted: Wed May 16, 2012 6:06 am
by eduardotama
I have not tried even with the octane converter. The octane3dsmax plugin says, convert vray materials. I had not happened
I hope it works.
Thanks for answering and sorry for my bad English
Posted: Wed May 16, 2012 6:07 am
by Karba
eduardotama wrote:I have not tried even with the octane converter. The octane3dsmax plugin says, convert vray materials. I had not happened
I hope it works.
What plugin version do you use?
Posted: Wed May 16, 2012 9:49 pm
by marcio_max
I think the solution to your problem is here:
