Page 1 of 3
how to turn off the reflection?
Posted: Tue Jun 01, 2010 3:18 pm
by mantra
i set specular to 0
but material still have a reflection
Y?
I can not use greyscale images like masks?
Re: how to turn off the reflection?
Posted: Tue Jun 01, 2010 3:41 pm
by radiance
This is because of the material type used, it's a glossy layer ontop of a diffuse material, it's always glossy.
You can turn up the roughness slider to make it look more like a diffuse.
You can map all channels with images...
Radiance
Posted: Tue Jun 01, 2010 3:45 pm
by mantra
how to do that would be one part of the material was reflected, and the other not?
Posted: Tue Jun 01, 2010 3:47 pm
by radiance
mantra wrote:how to do that would be one part of the material was reflected, and the other not?
We don't understand what you're saying maybe try to reword the sentence...
Radiance
Posted: Tue Jun 01, 2010 3:54 pm
by Flyx
I think he's asking if it's possible to use a grayscale image to make only some part reflect and not other.
Posted: Tue Jun 01, 2010 3:56 pm
by Daniel79
i think so
Posted: Tue Jun 01, 2010 3:57 pm
by mantra
Yes!)
by n1k
With mix material you will be able mix glossy and diffuse materials.
Posted: Tue Jun 01, 2010 4:01 pm
by obz
White will make make the material diffuse, and black will make it specular/reflective if you map the roughness with a black and white map.
Use a checker, you will see what I mean.
Then apply the inverse to the specularity.
Posted: Tue Jun 01, 2010 4:21 pm
by mantra
how? Octane does not have a mix material
obz,
Does not work.
Maybe I did not do so.
You could make a screenshot? Just make the material diffuse red plz
