Re-export scene
Posted: Fri Apr 27, 2012 8:20 am
by Area D
Hi to all!
I have a question... if I make a change in Rhino and then re-export the scene I lose all the materials already set
..there is a solution to this problem?...Or am I doing something wrong?
Re: Re-export scene
Posted: Fri Apr 27, 2012 4:50 pm
by gmillas
hi Area D
First have you saved the scene in a file.ocs ?
if yes then go to rhino and do only the exportmesh and in octane reload the .obj file you have just created.
Octane will retain your previous settings and will add the new materials from the new .obj file
Hope i helped
Re: Re-export scene
Posted: Mon Apr 30, 2012 7:26 am
by Area D
sorry but I can not find this option ..
Re: Re-export scene
Posted: Thu May 03, 2012 2:55 pm
by gmillas
Press on the .obj object in the node editor and at the properties at the right side of the window there is a disk drive like button.
Press it and it will open a selection window. Select the new .obj file and press ok .
All done
Hope i helped
