Strange Multi GPU issue
Posted: Sun May 30, 2010 6:50 pm
Hi, Wonder if anyone has experienced this (currently using the latest demo release)
With Sli DISABLED and Octane setup for multi-gpu I am getting the exact performance figures on all scenes, e.g benchmark scene with one card has the same rate as when the multi gpu's are setup .....the strange thing is with 2 instances of GPU-Z enabled you can see each cards load is around the 90% mark and the memory load is identical on each thus are working side by side...
Using 2x GTX 280's, latest nvidia drivers on a fresh install of 7. Have tried everything from setting physx to one card then the other followed by off. With NVIDIA's latest control panel the Sli menu has been improved and you can see for sure the exact setup which is how I understand the issue must be somewere else.
Its as if I'm running 2 instances of the same scene but can only see the results and performance of 1........if that makes sense!?
