Page 1 of 3
any last minute requests for procedurals ?
Posted: Tue May 25, 2010 6:04 pm
by radiance
Hi guys,
I will have about 2-3 hours tomorrow to add a few final procedurals that will have to last a few weeks in 2.2 final.
I was thinking adding besides the existing 'turbulence', also 'fbm' (which is similar) and ridged multifractal noise.
These are quick and simple to implement with the existing noise code we've developed.
Maybe also a 3d brick texture would be handy. with parameters for mortar thickness, and x, y, z scale of the bricks.
Are there any other things (non-complex things, eg nothing like gradient bars that require hours of UI work) that people would want ?
Yours,
Radiance
Re: any last minute requests for procedurals ?
Posted: Tue May 25, 2010 6:12 pm
by [gk]
I have meant to look into the proceduals when I got some time, after I sorted that other thing which is hanging..sry, too much work.
But when I do I will add some surgestions, but not only the materials, but also functions and relations.
Anything you can shove in is gladly appriciated.
I am thinking, 5-10 different types of noise..like Bercon maps for 3dsmax, those are great.
Ill list when I can
mads
Posted: Tue May 25, 2010 6:24 pm
by kubo
totally agree on a brick-tile type of procedural, it would be awesome!!!!
thanks
Just think, add your procedural wood to a tileable with a random color variation and boom, any wood floor you can think of!!! as big as you want!!, wow... such posibilities..
Posted: Tue May 25, 2010 7:17 pm
by pedrofelipe
if u make the brick procedural very editable we can even do tiles, floor and stuff! that would be great!
Falloff would be a great thing to add!
Fractal noise if it isnt asking too much!
Posted: Tue May 25, 2010 7:28 pm
by radiance
pedrofelipe wrote:if u make the brick procedural very editable we can even do tiles, floor and stuff! that would be great!
fallof = ?!
do you mean a gradient texture ?
Radiance
Posted: Tue May 25, 2010 7:37 pm
by pedrofelipe
kind of but without a UI to controll it lol
oh also... there's something on fryrender that is really handy... its a film coating... but a plastic one... like we have the film coating! (that generate that colours gradiants) I dont know since there's already a coat is it too hard?
Posted: Tue May 25, 2010 7:48 pm
by radiance
hey,
a linear gradient you can make with the sawwave texture.
non-linear curves are for 2.3 as i won't have time to code the UI stuff for that tomorrow.
also, i don't understand about the coating, we already have a thin film coating on glossy and specular materials, is this what you mean or not ?
Radiance
Posted: Tue May 25, 2010 7:53 pm
by pedrofelipe
Never mind... I dont know how to explain! I go back to my dark-corner!
BTW, a little examples/explanation about the new nodes will be great... I don't know the other guys... but I dont know what to do even with these rc3 nodes!
Posted: Tue May 25, 2010 8:01 pm
by vimaxus
3ds max falloff works like mix between the two values you give (or textures or materials even) and the mix percentage is the angle between the camera and the surface but expressed as a percentage (0-90degrees=>0-1) so if you give black-white values you get a gradient from black perpendicular to white tangent but in a different formula than fresnel (it changes much faster)
Posted: Tue May 25, 2010 8:16 pm
by radiance
vimaxus wrote:3ds max falloff works like mix between the two values you give (or textures or materials even) and the mix percentage is the angle between the camera and the surface but expressed as a percentage (0-90degrees=>0-1) so if you give black-white values you get a gradient from black perpendicular to white tangent but in a different formula than fresnel (it changes much faster)
why would you need this ? can you give me a particular example in practice ? i find it difficult to picture a use for this.
Radiance
