*request* Computer optimized for Octane and Maya
Posted: Wed Mar 28, 2012 11:44 am
by Att3ro
My computer is getting to out of date, and I want my new computer to be optimized for Octane and Maya. So for both normal working with Maya and rendering with Octane, so what is the best that I can get for my budget that I've set for it 2200€ (euros). Could be a bit more or a bit less, but around that number. And I'm in now hurry, so take your time if your are willing to help.
Regards,
Att3ro
Re: *request* Computer optimized for Octane and Maya
Posted: Fri Mar 30, 2012 4:29 pm
by michaelkdaw
In general: if you're going to render with Octane, don't get too hung up on getting an expensive CPU. Octane doesn't use it. Spend that money on a more powerful video card. It will help your viewport performance in maya, and your rendering speed in Octane.
That's certainly not to say that a powerful CPU is not an asset. It is. But these days, reasonably powerful CPUs aren't necessarily expensive. Unless you go for the super high-end models. The performance advantage per dollar (or whatever currency you're using) decreases dramatically as you start looking at the higher-end.
In my opinion, a Core i7 2600K is LOTS. Someone else may have further insight.
Posted: Fri Mar 30, 2012 5:38 pm
by Att3ro
I will certainly look into that. Thank you for the response.
Att3ro
Posted: Fri Mar 30, 2012 5:56 pm
by t_3
as i put together some parts for a friend recently, this might be of use for you also:
ASUS P8P67 WS REVOLUTION LGA 1155 Intel P67 / NVIDIA NF200
http://www.newegg.com/Product/Product.a ... 813131714R
Corsair CWCH80 Hydro H80 CPU Liquid Cooler
http://www.compusa.com/applications/Sea ... &CatId=499
Mushkin Enhanced Blackline 16GB (2 x 8GB)
http://www.newegg.com/Product/Product.a ... 6820226316
2x ZOTAC ZT-50103-10P GeForce GTX 580 3GB
http://www.compusa.com/applications/Sea ... CatId=3669
SilverStone Fortress Series FT02S-W Silver Aluminum / Steel ATX 220
http://www.newegg.com/Product/Product.a ... 6811163183
COUGAR CMX 1000 COUGAR-1000CMX 1000W
http://www.compusa.com/applications/Sea ... CatId=2535
if you add an i7-2600k, this is still well below 2000 euros. because of the nf200 chip, the board delivers 8x speed to all pcie slots, also the slot arrangement would allow a third card (or a fourth, with the bigger silverstone case). btw, regarding the case, i didn't go for anything else - maybe silverstone tj07 (same size) or tj11 (bigger) - best airflow...
Posted: Fri Mar 30, 2012 6:16 pm
by Att3ro
Wow thanks a lot, will certainly look into it. Now I just need to finish work...
Thanks again,
Att3ro
