				Add Material
				Posted: Thu Apr 08, 2010 10:36 am
				by Daniel79
				I try the new beta2..is amazing!
I'd like to know if possible, when i import obj file whitout material definition, add a different material into octane:
When i import obj all is white and i have only one material for all objects.
If i change the color all objects change color.
If possible change color for each object into octane or i have to change this into my modelig software?
I hope you can understand me because my english is BAD!!
Thanks a lot!!
				Re: Add Material
				Posted: Thu Apr 08, 2010 11:01 am
				by Sam
				Currently you need to assign different materials in your modelling application (with different names like wood, concrete, kitchenfloor01 etc...)
Then Octane will see the different materials and keep their names
				Re: Add Material
				Posted: Thu Apr 08, 2010 11:33 am
				by Daniel79
				But in the future you belive is possible do whta i say?
				Re: Add Material
				Posted: Thu Apr 08, 2010 11:49 am
				by mlody47
				If Your asking about something like this?? Than I know how to do that.
I've had empty nodes with no materials attached to it, and then I was connecting those
				Re: Add Material
				Posted: Thu Apr 08, 2010 11:59 am
				by Daniel79
				Each triangle into node of node rappresent very single object in the scene?
If yes..maybe thiis is answer at my post!!
Thanks, thanks
				Re: Add Material
				Posted: Thu Apr 08, 2010 12:32 pm
				by mlody47
				No. Triangle means that it already read from materials name of imported OBJ. If it doesnt, it leaves emtpy circle, and if You connect material there it will fill up. You will have material added in nodegraph , but its basicly the same thing. I was making this becouse I forgot to change some names, and something didnt import.
				Re: Add Material
				Posted: Thu Apr 08, 2010 1:19 pm
				by yijian4515
				Wow,isn't every object have add ShadingGroup in other software.and if i can't add ShadingGroup in maya ,isn't have other method?
				Re: Add Material
				Posted: Thu Apr 08, 2010 11:44 pm
				by mlody47
				yijian4515 wrote:Wow,isn't every object have add ShadingGroup in other software.and if i can't add ShadingGroup in maya ,isn't have other method?
What do you mean?? You cant add materials in maya?? or I dont understand something.?
				Re: Add Material
				Posted: Fri Apr 09, 2010 2:04 am
				by yijian4515
				mlody47 wrote:yijian4515 wrote:Wow,isn't every object have add ShadingGroup in other software.and if i can't add ShadingGroup in maya ,isn't have other method?
 oh, i'm sorry i mean i not add materials in maya,isn't have other method?
 sorry my english bad.
				Re: Add Material
				Posted: Fri Apr 09, 2010 6:05 pm
				by Proupin
				Currently an imported obj mesh will not allow you too selectively apply materials to the objects individually, as they are "linked" from the export operation to the materials you may have applied in Maya. JUST apply different materials to the objects in Maya. One material per object if you want. You would virtually have one input material per object when imported in Octane.
