Page 10 of 32
Re: Cinema4D 2022.1 (Latest stable) (19.11.2022)
Posted: Mon Dec 05, 2022 11:51 am
by aoktar
AaronWestwood wrote:
Totally understand. It is urgent, purely as I would love to start using the wonderful features of 2022 for a job im on as it would elevate what I can do, but cant as its 100% scatter dependent.
How long would a fix take/the other fixes take? Is a new version days/weeks out?
Thanks for the reply.
Can't give exact timing. Depends to success of our progress on addon and fixes. Maybe in a few days. Btw you can easily work-around it. For example disconnect effector then delete it.
Posted: Mon Dec 05, 2022 12:00 pm
by AaronWestwood
A few days is totally fine. Will keep an eye out.
I have a ton of scatters connected to dozens of effectors that im tweaking/changing so disconnecting/reconnecting is so out of habit that I find myself crashing by accidently deleting. User error navigating this "fix" for sure. Will stay in 2021 until the fix is ready.
Posted: Tue Dec 06, 2022 4:04 pm
by azumbrunnen
I'm using this version on a render farm with Windows. Is this fully interchangeable? I sometimes get strange render artifacts and vdb's not loading correctly.
Posted: Tue Dec 06, 2022 4:27 pm
by aoktar
azumbrunnen wrote:I'm using this version on a render farm with Windows. Is this fully interchangeable? I sometimes get strange render artifacts and vdb's not loading correctly.
can you contribute more about issues?
Posted: Tue Dec 06, 2022 5:20 pm
by azumbrunnen
Yes VDB loader often has repeating frames. I.e. it just shows the same frame 3 times in a row instead of properly loading the next VDB. It's completely random though and it's not reproduceable. When I re-render, the next time it happens on other frame ranges.
Posted: Tue Dec 06, 2022 5:40 pm
by Kalua
Plugin is working great, Aoktar! Thanks!
Not sure anyone reported it yet:
Gradient on complex mode is not updating the node pins, wheter it's new gradient node or an already existing complex gradient where I am eliminating values.
Sometimes it updates, sometimes it doesn't.
Posted: Tue Dec 06, 2022 9:02 pm
by aoktar
Kalua wrote:Plugin is working great, Aoktar! Thanks!
Ok I'm checking it, not reproduced yet but thanks! You can press to "Get active material" as work-around. Sending a sample scene may help to see the issue
Posted: Wed Dec 07, 2022 11:08 pm
by Kalua
Thank you. If I find a consistent reproduceable scene I will send you.
Regards,
Posted: Thu Dec 08, 2022 1:30 am
by SSmolak
Octane Texture Manager can't find any of the missing HDRI maps from Octane Sky Object. It even not shows them if they are propely linked. It doesn't accept relinks from C4D Project Asset Inspector.
I noticed this months ago but working now with larger scene this is more noticeable - Octane sometimes when operations take little longer automatically switch to 2x2 subsampling mode and stay with it until manually it will not disabled. I have set Perf.timer to 1000. Is this really needed ?
Material Layer for Standard Surface doesn't work right ?
Posted: Sat Dec 10, 2022 9:02 am
by freeter_e
modify multiple material colors
matertial preview, not refresh
i test on v2021.1.4-R4,it's ok
on v2021.1.6-R6,v2022.1,it noesn't work
