Page 10 of 13
Re: OctaneRender 3 for Poser (Windows/OSX) [TEST and STABLE]
Posted: Tue Aug 22, 2017 8:25 am
by Erick
Even tho it is, sadly, really deserted here ~sees another tumble weed rolling by~, thank you SO much, for continuing to maintain and develop the Poser plug in!!!
Posted: Fri Sep 01, 2017 11:47 pm
by wimvdb
One problem I ran into was that I needed to install as Administrator.
All previous versions of the plugin did not require that
After installing it as administrator it all works fine
Posted: Sat Sep 02, 2017 12:57 am
by face_off
Thanks Wim - I cannot think why this would be needed. Can you tell me the error you have when installing from your user account?
Posted: Sat Sep 02, 2017 10:33 am
by wimvdb
This error:
Running the setup with admin privileges works
Posted: Sun Sep 03, 2017 8:13 am
by Erick
Hm, I didn't have this error, when installing this new build.
I could install it without any special (Admin) privileges.
Posted: Sun Sep 03, 2017 8:23 pm
by wimvdb
I tried the previous build and that worked normally (no admin needed)
First time I encountered it
Posted: Mon Sep 04, 2017 12:01 am
by face_off
Very strange. There should be a new build shortly, can pls check it to see if the problem has gone away or not.
Posted: Wed Sep 06, 2017 6:35 am
by face_off
Following is another pre-release of the Octane 3.07 build of the plugin - this version has been compiled with Octane 3.07 TEST 4, and contains changes to the LiveDb thumbnail bitmaps.
https://render.otoy.com/customerdownloa ... _Win64.exe
Posted: Thu Sep 07, 2017 9:02 am
by Erick
Thank you for the update.
Looks fine and stable to me so far :!:
Posted: Fri Sep 15, 2017 12:03 pm
by face_off
I have added a test build to the top of this thread with:
3.7.0.84
- Compiled with Octane 3.07 TEST 6.
