Page 10 of 14
Re: OctaneRender® for 3ds max® v1.50a
Posted: Tue Apr 15, 2014 9:41 pm
by coilbook
Thank you for your reply I tried everything. I have mix material for top part as checkers and it shows as pure black in viewport but fine when rendered. I attached 2 images. But bottom part shows fine as green because it is jsut a diffuse material and not a mix material. may be 3ds max 2014 glitch. Thank you
Greg
Posted: Tue Apr 15, 2014 9:42 pm
by coilbook
Here is a max file maybe someone knows the answer Thank you very much
Posted: Wed Apr 16, 2014 6:28 am
by j7th
coilbook wrote:Here is a max file maybe someone knows the answer Thank you very much
OctaneRender materials and texmaps doesn't support "Show Shaded Material in Viewport"
IMHO black color - because Mix material doesn't have proper implementation of "void Mtl::Shade(ShadeContext& sc)" and/or "Color Mtl::GetDiffuse(int mtlNum, BOOL backFace)"
Posted: Wed Apr 16, 2014 7:13 am
by GlobalMarketing
Karba wrote:GlobalMarketing wrote:Hi there
I have a problem with octane render animaition minute
Normally render time 22 seconds frame of but when i was rendering sequence 20 to 130 the render time frame of 01:22 minutes
Why the time is too different octane viewport and max render frame
Can you help me how can i fix this?
Thank you.
Do you have any geometry animation for that sequence? Did you try to switch off "update animation geometry" option?
Yes the scene commercial automotive animation.Are you talking aobut autoupdate movable proxy switch ?
Posted: Wed Apr 16, 2014 8:47 am
by GlobalMarketing
GlobalMarketing wrote:Karba wrote:GlobalMarketing wrote:Hi there
Thank you.
i found thank you.
Posted: Thu Apr 17, 2014 9:10 am
by Angelos
I still have a problem with animation sequences.
Now I have only half rendered 138 of 250. And then the renderer was stopped by itself. WTF?
Posted: Thu Apr 17, 2014 7:55 pm
by Karba
Angelos wrote:I still have a problem with animation sequences.
what does octane error log say? looks like your gpu gets overheated or it is a power supply issue.
Posted: Thu Apr 17, 2014 8:05 pm
by Karba
i found thank you.
Do all frames take 1:22 minutes or just first one? Don't forget that first frame always takes more time due to geometry preparation, but next one takes less.
Posted: Thu Apr 17, 2014 8:36 pm
by vfxman83
Hi global marketing is my office account this is personal
All frames 1:22 minutes 130 frames rendered about 3 hours with pal resolution 756x576
Posted: Fri Apr 18, 2014 12:49 pm
by Carl S.
Karba wrote:Angelos wrote:I still have a problem with animation sequences.
I have the same issue, render just hangs after so many frames. I do not think it is power supply or overheating, I have Cubix boxes. Where can I find the error log?
