Page 10 of 19
Re: OctaneRender® for 3ds max® v1.0 beta 2.56 [NEW/CURRENT]
Posted: Fri Dec 23, 2011 4:56 pm
by j7th
for me vray material converter don't work with vraylight materials
Posted: Fri Dec 23, 2011 5:40 pm
by satori13
it does not work indeed!:(
Posted: Fri Dec 23, 2011 5:47 pm
by gabrielefx
j7th wrote:for me vray material converter don't work with vraylight materials
in fact it doesn't convert vraylightmaterials...
Posted: Fri Dec 23, 2011 5:48 pm
by gabrielefx
thomasmesser wrote:It's my little wisch list:
1-working with animated textures (avi or image sequences)
2-camera only render without reloading scene to gpu- this can speed up render in simple scenes when only camera is moving.
3- stereo render support in various modes - Side by side , over and under, interlaced- it makes possible to preview render scene on 3D TV in realtime
+1.000.000.000
Posted: Fri Dec 23, 2011 7:30 pm
by Truefin
OK, so i just purchased the 3ds Max plug-in and have found a bug. (I know I know we are beta testing the product. I'm just looking to help)
PC Specs: Windows 7 64Bit, 3ds Max 2012, GTX 580 (using one card for graphic display and rendering)
Bug: Right Clicking the OctaneRender Viewport causes 3ds Max to crash.
Process:
1. Opened 3ds Max
2. Assigned OctaneRender as the render engine
3. Created a plane and 2 teapots
4. Changed Environment color to white
5. Selected Open Octane Render Viewport
6. While OctaneRender Viewport was opened right-click on the screen.
7. Received 3ds Max Application Error. (Max crashes)
Posted: Fri Dec 23, 2011 7:57 pm
by KaroBastardKiter
KaroBastardKiter wrote:
At startup of 3ds max: Error 126 - the module could not be found.
Any ideas why I am receiving this message? :(
check your firewall
I shut down the firewall completely but I ge the same message.
I am running a 32bit 3ds max on a 64x Windows 7, could that be the problem?
Has anyone had the same problem?
Posted: Fri Dec 23, 2011 8:12 pm
by j7th
then i assign image texture to diffuse slot, the 3ds max button "Show standart map in Viewport" dosn't show texture in max viewport
Posted: Fri Dec 23, 2011 8:47 pm
by MaTtY631990
This could be a small bug, if not it might have been overlooked. If you are in a project at the moment you can just load a bitmap and use them as you would while doing any UV unwrapping. Just remember to put the textures into a image/floatimage texture node before final rendering.
Posted: Fri Dec 23, 2011 11:39 pm
by obadonke
obadonke wrote:where would you like bug reports? I can get consistent crashes trying to use an Octane viewport with 3Ds Max 2012x64 on my Win7 machine (2xGTX570) but plugin works fine as a renderer.
I installed 3ds Max 2012 x32 SP2 to investigate stability issue. Turns out there is a method to create an Octane viewport in 2012 x64 that doesn't exist in 2012 x32 namely:
1) left click the POV viewport label menu
2) choose Extended Viewports->Octane
3) you will probably get a crash soon after!
Since I hadn't understood Page 11 of the Octane plug-in manual, I thought this was the correct way to launch an Octane viewport. Therefore I always got crashes.
This Extended Viewport menu item doesn't exist in 3ds Max 2012 x32.
Now that I'm using the "Open Octane Viewport" button from the render settings panel, I can happily say that Octane viewports work for me in both x32 and x64 versions of 3ds Max on Win7x64 2xGTX560 (3 monitor set up, 1 on primary card, 2 on aux card - primarily a gaming rig).
I do get the right-mouse-click-in-viewport crash in 2012x64.
I don't get the right-mouse-click-in-viewport crash in 2012x32.
Posted: Sat Dec 24, 2011 11:30 am
by MaTtY631990
This is what I have with the same results for both camera and render settings in both octane standalone and octane3dsmax
OctaneStandalone
Octane3dsmax
Anybody have a thought or have tried a comparison. I am wondering whether you need to fiddle with 3dsmax gamma, or something, but does not explain the big noise difference.
