Page 9 of 62
Re: OCTANE BENCHMARK: Submit performance scores for your rig
Posted: Sun Dec 09, 2012 7:58 pm
by suvakas
cfrank78 wrote:I get about 1.93 with my gtx 560TI and about 2.27 with my gtx 660 TI MSI.
What render mode are you using?
I get similar results as you with path tracing.
When using PT my gtx 560 scores 1.63.
Suv
Posted: Sun Dec 09, 2012 8:01 pm
by Refracty
maybe they used an older version 2.58 wich was faster
Posted: Sun Dec 09, 2012 11:38 pm
by cfrank78
Suv
I used Pathtracing with the optiones i should use, told in the first post. Alphashadows disabled and so on. But i thing the guys in the other threads used pathtracing too right?
Refracty you tell me 2.58 was faster than the final release? did i understand you right? Why is this? Thats strange!
Kind regards Chris!
Posted: Mon Dec 10, 2012 11:41 am
by Refracty
Hi Chris,
to embed instancing functionality the new releases are a little bit slower then 2.58 release.
So there is a difference of speed results depending on what release was used for the benchmark.
Posted: Mon Dec 10, 2012 11:53 am
by cfrank78
Hi Chris,
Hi Refracty!
Thank you very much. Everythings clear now. Was a bit shocked, cause of my low MS/S. On last Question to you, cause as i saw you had the highest Results so far here. I will build a new Computer in January. Dual Xeon 6 Core for rendering in Vray and also 4 GPU´s. What do you think would be best for Octane Refracty? 4 580 from Ebay? 4 680 (4gig) from store. i know 690 or 590 would be best but i cant´t effort them. What would you buy? Be honest please - whats the best i can built in today for about 2000 Euro just for Graphics Card?
Kind regards Chris!
Posted: Mon Dec 10, 2012 5:14 pm
by Refracty
4 * 580s 3GB or 4 * 680 4GB are both good choices. If you don't want to water cool (what will raise the costs) I would go with the 680s. They consume less energy and doesn't heat up so quick.
580s are 10 % faster but the 680s will give you a bit more textures and VRam.
So If I would choose a system today I would go with 4 * 680s in an air cooled case.
Posted: Mon Dec 10, 2012 5:31 pm
by cfrank78
Thank you very much - i think i will get the 680. I think that Kepler will be faster in the future - when new updates will come. Fermi is hard to get and new customers wanna have speed too :-) They will have to push kepler, not fermi hehe! Thank you very much for your tipp!
Posted: Thu Dec 13, 2012 9:24 pm
by sternbach
1x Gigabyte Gtx 670 Oc 4Gb, Octane Render 1.0, PathTracing, AlphaShadows set to false.
GPU Core Clock while rendering: 1149.7 MHz
GPU Memory Clock: 1502,3 MHz
GPU Temp ~ 55 °C
GPU Load 99%
Leads to 2.91Ms/sec.
Environment:
Windows 8 Enterprise, 64bit
ForceWare 306.97
I7 2600k
Asus P8Z68-V Pro
16Gb
Posted: Fri Dec 14, 2012 12:50 pm
by igen
glimpse wrote:
igen wrote:I forgot the detail .... 2 zotac gtx 690 ~ 44Ms/sec use pathtracing
Are You sure? =) Any printscreen to base Your performance claim?..
Sorry for my mistake not with patchtrahing but 46 Ms/sec with direct lighting. :?
Posted: Fri Dec 14, 2012 3:38 pm
by fovito
1 x GTX 660TI (Asus, 2GB)
OctaneRender 1.0 Final
= 2.23 Ms/sec.
Pathtracing / AlphaShadows disabled
