Page 9 of 13
Re: good or bad idea: 5.5K euro for machine 2xTitanZ
Posted: Fri Nov 14, 2014 11:08 pm
by Laticis
Hi Rappert,
LOL on the PSU - our PC's just found their doppelgänger :)
Actually Gigabyte for the GPU
I didn't put the PC together, I went through a company called Mwave and I new it would come with the SLI Bridge and I have been wondering the same thing,
is that causing the issue.
I was hoping to have the ability to just switch between the two options for specific needs ie Gaming / Octane without the need for touch that cable.
Posted: Fri Nov 14, 2014 11:19 pm
by Laticis
Removing the cable has had no effect....back to the drawing board.
Posted: Fri Nov 14, 2014 11:22 pm
by rappet
Laticis wrote:Hi Rappert,
Hi Laticis,
If you have the bridge on.... You still can enable and disable sli in the config.
You can turn it on for gaming and off for Octane very easily.
I noticed earlier that having the sli enabled does not make that much difference for renderspeed on Octane.
You can try it.
About the sli bridge... I was just wondering, because It hink I understood it correctly from my PC builder,
that these days the hardware bridge would not be needed to have sli running,
But I have to say I am not sure... So if somebody else could confirm or disconfirm would be nice.
Then you having the problem of not seeing the second TitanZ made me wonder if the bridge is bugging something.
Cheers,
Posted: Fri Nov 14, 2014 11:37 pm
by Laticis
Hi Rappert,
I am going to put it back on for and see that there will be a lot of testing in the future.
Both cards are there, they are showing up in Device Manager and the NVidia Profile.
Attached screen shot show one of those GPU in Octane Disabled and the clean cut down the middle for the Ms/Sec
Either I am missing something or this is what it is, but it doesn't feel right.
Posted: Sat Nov 15, 2014 12:00 am
by rappet
Hi Laticis,
The Screenshot shows two TitanZ, but in fact it is just one card with two GPU on it.
You disabled one GPU, but in fact it is one GPU of the two GPU on one videocard.
The renderspeed of less then 8 comforms this.
The renderspeed of one videocard should be appr. 15.5
So for one TitanZ videocard it shows two times in the Octane or monitor software,
If both your cards would be recognized, in Octane it should show four times a TitanZ !
Hope this makes sense.
Have you confirmation by monitoring software that both the videocards are recognized and active (outside of Octane)?
Otherwise, I would unplug one card from the mobo, and then the other to make sure they are both working seperately.
Cheers,
Posted: Sat Nov 15, 2014 12:04 am
by rappet
Hi Laticis,
I have one TitanZ and two Titan Blacks,
But in my monitor software it is like this:
1. Titan Black
2. TitanZ
3. TitanZ
4. Titan Black
Posted: Sat Nov 15, 2014 12:18 am
by Laticis
Hi Rappert,
That would actually make sense if by "montior" meaning LCD Screens....
rappet wrote:Hi Laticis,
1. Titan Black
2. TitanZ
3. TitanZ
4. Titan Black
After everything I have tried, including driver update still only 2 x GPUs showing in Octane.
Posted: Sat Nov 15, 2014 12:34 am
by rappet
1. Titan Black
2. TitanZ
3. TitanZ
4. Titan Black
Hi Laticis,
Pardon my French :oops:
I mean monitoring software, by monitoring your GPU using software likE MSI afterburn or EVGA precision X.
Greetz,
Posted: Sat Nov 15, 2014 12:38 am
by rappet
Laticis wrote:...After everything I have tried, including driver update still only 2 x GPUs showing in Octane.
Have you checked them seperately
I.e. by unplugging one, and then plug in only the other?
To make sure both your cards are OK?
Greetz,
Posted: Sat Nov 15, 2014 12:43 am
by Laticis
Hi Rappert,
LOL the French excused :)
Oh, well that's a good sign for and a bad sign for me.
rappet wrote:Have you checked them seperately
Tried everything else and will do that next, very possible things shifted during transport.
I did have to reseat the ST HardDrive seated between the two GPUs
Need to head out for a bit, need some Lan cables for the NAS....one I get back will post an update.
Thanks heaps for all your help :)
Cheers Ady
