Page 9 of 14
Re: Version 1.51.0 (based on Octane 1.51)
Posted: Wed Apr 09, 2014 2:09 pm
by aoktar
Silverwing wrote:Hi and thanks for all your responses especially shawnfrueh!
Other suggestion:
If the Untonemapped is correct that way I´d rather stay with 32bit tonemapped as shawnfrueh suggested.
Would it be possible to not clamp the Tonemapped 32bit output as I really need the above 1 values in compositing?
Cheers,
Raphael
sended to you a PM for test
Re: Version 1.52.1 (Octane Render 1.52) *** 10.04.2014 ***
Posted: Thu Apr 10, 2014 9:00 am
by anti86
Hi guys!
I just bought the full version of octane render yesterday and it's just amazing!
A small problem though. I used the demo for some while before i bought the real deal it seems, that everything is working a bit slower.
Although i got faster results in the final rendering, the c4d interface itself is showing some lag when the live viewer is open. Also, settings windows load up slower. Than wasn't the case with the demo.
Is there something i can do to fix this?
GTX 680 4gb
32bg ram
i7 3390
Thank you for your great work!
Posted: Thu Apr 10, 2014 9:03 am
by aoktar
anti86 wrote:Hi guys!
GTX 680 4gb
32bg ram
i7 3390
first, welcome here. Nice decision. I think you should check render priority of gpu's from Settings window. If you set on and low for gpu which is used for viewport, you should work smoothly.
Posted: Thu Apr 10, 2014 6:05 pm
by Ron
Hi Ahmed,
with the current version the live db is not loading materials etc. It shows an empty window which says in the status bar: MSG:loop.
Any ideas?
Thanks and regards - Ron
Posted: Thu Apr 10, 2014 7:01 pm
by cleanerxx
liveDB is working totally fine for me
Posted: Thu Apr 10, 2014 7:59 pm
by aoktar
Ron wrote:Hi Ahmed,
Any ideas?
version of c4d?
Posted: Fri Apr 11, 2014 3:50 am
by pavel
Hello aoktar, it keeps crashing and i am getting the same error when doing random stuff, like copy/pasting objects or textures, or sometimes just navigating the viewport. It doesn't seem to happen when i do something in particular. It's not a texture or objects, because after i reload the scene, i use the same objects and textures and this time it doesn't crash. Does anyone else get these errors, or is it just me?
Cheers,
Alex
Posted: Fri Apr 11, 2014 8:46 am
by TBA3D_70
Ron wrote:Hi Ahmed,
Any ideas?
The same on mac os x 10.9.2 and C4D R15.057.
Without internet connection -> no materials (downloaded all in the previous versions) in the stored library visible. But they are all stored on the hard drive !?
With internet connection -> all fine.
Also have problems with the texture emission. Different results in the LiveViewer and the PictureManager output.
Only the same result, if I boost the emission float slider 10x higher than before.
This way I can reach the previous LW-results after this step, but then the current LW-result is 10x higher/brighter also.
Please have a look there!
Is the C4D-Foreground Object also working with octane in the near future? The Background Object is supported from octane !
Would be nice for animated black and withe shader/gradients, etc. for scene blending directly inside C4D/Octane.
Maybe you can add support for the free "Tools4D Spline Shader" !? ... or must I ask the developer for octane support ?
Thanks and best regards,
Thomas
Posted: Fri Apr 11, 2014 12:57 pm
by aoktar
Hi Pavel,
i think you get soo much crashes, it's not normal. Can you post some additional info? this is not usefull. I need some bugreport.zip when you get it. If you get crash go and get bugreport.zip, and pls send me a few different bugreport.zip. Also pls attach a few words when you get it.
Btw, did you installed standalone with installer exe?
Posted: Fri Apr 11, 2014 12:59 pm
by aoktar
Thomas
Livedb is designed for internet connection, in some old versions, i added a caching method for working offline. But this is broken now because of changes of sdk. Maybe i can fix for future.
Background and foreground objects are possible. In samples.zip, there is some scenes for that. you should put a standart material to background or foreground object.
For brightness problem, i'll look it
