Page 9 of 11
Re: OctaneRender® for 3ds max® v1.02[Test]
Posted: Tue Jan 22, 2013 7:59 pm
by Karba
cfrank78 wrote:Can someone please fix that stupid problem with the fokus picker??????????????????????
I played with 3 projects and had to use the fokus picker and simply the sharpness was bad. its a complete guess play when you move the camera along a path ......and NOOOOOOOOOO - i can NOT use a bigger aperture. i need the depth of field. Hey Karba please fix those problem. Octane for 3ds max is USLESS like this and we payed for it!!
Going back now to 1.00 untill you fixed it.
And yeah - i am angry now cause i wasted lots of hours!
Chris!
I will fix that for the next release.
Posted: Tue Jan 22, 2013 8:02 pm
by Karba
merid888 wrote:hi karba, i cannot open the viewport octanerender into 3ds max, i have driver installed 310.90, using right now 2 gtx470, windows xp64 bits, add image and file .rar, 3ds max 2013 x64 and octanerender for max 1.02, standalone 1.03
Please check your licence activation.
What is your multiple GPU nvidia setting? multi-GPU mode should be disable.
Posted: Tue Jan 22, 2013 8:04 pm
by Karba
marcio_max wrote:Multiscatter is no working!!! Fix this, please!
It works
Posted: Tue Jan 22, 2013 9:06 pm
by gueoct
suvakas wrote:I'm sure Camera correction modifier is not supported. It's a tricky thing to implement.
Use "LensShift" under Octane camera instead.
Point your camera directly to cam's target (so that cam Z = target Z) and then play with lens shift x/y values to get your verticals straight.
What still sucks is the fact that you don´t see the Shift effect in the Camera viewport.....
Posted: Wed Jan 23, 2013 12:05 am
by merid888
hi karba, i been used the plugin sunday without problem, today i star my pc, open 3ds max, load octanerender and when i give octane viewport just nothing happen, i need deactivate the license, wait one hour and activate again ?
please help me
second point, multiple GPU nvidia setting? where is this option in panel control nvidia ?
thank you
Posted: Wed Jan 23, 2013 12:19 am
by Karba
merid888 wrote:hi karba, i been used the plugin sunday without problem, today i star my pc, open 3ds max, load octanerender and when i give octane viewport just nothing happen, i need deactivate the license, wait one hour and activate again ?
please help me
thank you
What does licence tab say?
Posted: Wed Jan 23, 2013 8:11 am
by -EnzO-
hi Karba,
I have a big problem with this version... when i open the material editor, the materials dont appear... and i have to restart max because it crash...
I use max 2012, i'm on windows 8 pro 64 bits, i have a gforce 580 gtx (1.5Go) and i have installed the latest version of the nvidia drivers (310.90).
Same problem with the 1.01.
With the 1.0 RC3, no problem.
Do you have a solution ?
Posted: Wed Jan 23, 2013 11:31 am
by marcio_max
Karba wrote:marcio_max wrote:Multiscatter is no working!!! Fix this, please!
It works
Hi, Karba!
For me not works!!!
I'm using Windows 8 Pro x64
*** Problem solved! Just upgraded to the version of Multiscatter 1.1.09D and now everything works!
Posted: Wed Jan 23, 2013 12:39 pm
by merid888
hi karba, thank you, my control panel is different, i use driver to windows xp64 bits
i'll explore my control panel and i'll try to find that option
i talk about the licence in the octanelive accounts, i need deactive, wait one hour and activate again ?
regards
add image, none option like your image desable sli, why ? is the last driver 310.90
Posted: Wed Jan 23, 2013 5:14 pm
by merid888
same result, add image
