Page 8 of 10
				Re: OctaneRender® for 3ds max® v4.00-XB4 - 6.04 [TEST]
				Posted: Fri Aug 17, 2018 10:34 am
				by paride4331
				coilbook wrote:Hi is there anyway to create iridescent clouds ?  I mean the rainbow color effect.   Not sure where to begin Thank you
Hi coilbook,
maybe something like this, but I think you would set color grid for emission while you create your .vdb
paride
				Posted: Fri Aug 17, 2018 11:44 am
				by paride4331
				ramone163 wrote:Denoiser on large images crash Standalone and 3ds Max plugin.
Scene is only 1.5 Gb of VRAM. So how much denoiser need to render 5000x5000 pixel?
Please fix it.
Hi Ramone163,
the issue you reported is in SDK, it doesn't pendends on Octane for 3dsMax plugin.
SDK developers will fixe it.
Regrds
				Posted: Fri Aug 17, 2018 12:01 pm
				by paride4331
				justix wrote:I have problems in using cameras, it seems that now all cameras  values look like instancing in the the scene.. anyone?
 it is really annoying as I have 3 cameras with different FOV .. but any change made on one change change the same value on the other ones ????? + I just ha a GPU failure due to NOT ENOUGH MEMORY FOR DENOISE while having 4 Gigabyte free memory left? ( max 2018 )
Hi justix,
values change when using cameras instaced only.
are you sure they are not?
				Posted: Fri Aug 17, 2018 5:15 pm
				by justix
				paride4331 wrote:justix wrote:I have problems in using cameras, it seems that now all cameras  values look like instancing in the the scene.. anyone?
Hi justix,
Pretty sure as one has been created frm the Camera menu which usually use the same values of the last modified.. I will double check, as for the GPU fail I understand it's abug which I did not see it cleared in the last RC2 bug list? will the out of core option take care of any Denoise fal due to out of memory?
				Posted: Fri Aug 17, 2018 5:31 pm
				by coilbook
				paride4331 wrote:coilbook wrote:Hi is there anyway to create iridescent clouds ?  I mean the rainbow color effect.   Not sure where to begin Thank you
Hi coilbook,
paride
Thank you  !
				Posted: Sun Aug 19, 2018 2:51 pm
				by Juanlife
				not working on RC2 for me
				Posted: Mon Aug 20, 2018 9:01 am
				by ramone163
				More test:
It seems 3.08-XB4 have stability and viewport performance problems.
3.07-more or less OK.
Trying to render a lot of instances objects (one block) and when I hit render, viewport stack and I can't do anything.
Driver ver: 391.35
Check my videos.
				Posted: Mon Aug 20, 2018 9:22 am
				by HHbomb
				Any ETA on max version to solve problems with hight objects count, and heavy meshes ?
				Posted: Mon Aug 20, 2018 9:26 am
				by paride4331
				ramone163 wrote:More test:
Driver ver: 391.35
Check my videos.
Hi Ramone163,
Nvidia 391.35 should be good.
Try using 'Use obj render settings' option in the Kernel settings.
As I can see in your clip, using that Octane hardware setting, you have 3.3 GB avaible.
				Posted: Mon Aug 20, 2018 9:37 am
				by ramone163
				paride4331 wrote:ramone163 wrote:More test:
Driver ver: 391.35
Check my videos.
Hi Ramone163,
Hi Paride
"Use obj render settings" doesn't help.
I send you to PM my scene file. Please try to render it and check the viewport performance.
Thank you.
