Page 8 of 11
				Re: OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.8 XB3
				Posted: Thu Jul 12, 2018 8:31 am
				by scaphoide
in LW 2018 we try octane Render V4.0 beta but impossible to load an image texture.
The Octane Texture Image Node  don't open. When i clic on, nothing happens.
Any suggestions ?
				Posted: Thu Jul 12, 2018 9:19 am
				by juanjgon
				scaphoide wrote:Hi,
Any suggestions ?
Are you working with LightWave 2018.0.4 or 2018.0.5? The plugin is only compatible with these latest LightWave builds. If this is not your problem, please try to install the plugin again, adding it to the Layout after removing the Octane master plugin from the master plugins panel.
				Posted: Sat Jul 14, 2018 6:33 am
				by vipvip
				Hello,
with fiberfx + win10 + lw2018-64+octane XB3, the fiber-fx settings are automaticaly updating with IPR only when a LW2018 VPR is active or when surface-preview rendering (vpr too so) is active : when lightwave displays only OPENGL windows, IPR doesn't update FFX changes & need to reload fully (of course wirh FFX auto-update option enabled) : is it normal ?
				Posted: Sat Jul 14, 2018 6:34 am
				by vipvip
				and i expenrience still many crashes when updating objects from modeler to layout when IPR is active... (Still with XB3)
				Posted: Sat Jul 14, 2018 8:58 am
				by BorisGoreta
				Yeah this is normal. If you see fibers in OpenGL preview then fibers will automatically update in IPR, if you disable OpenGl preview then it will not update. This is very handy since you can decide weather you wish it to update or not.
vipvip wrote:Hello,
				Posted: Sat Jul 14, 2018 9:13 am
				by vipvip
				BorisGoreta wrote:Yeah this is normal. If you see fibers in OpenGL preview then fibers will automatically update in IPR, if you disable OpenGl preview then it will not update. This is very handy since you can decide weather you wish it to update or not.
OK thanks, good tip, i didn't know !
				Posted: Fri Jul 20, 2018 5:29 pm
				by pixym
				Just received my second GTX 1080 TI today and WOW… No more thing to write
				Posted: Fri Jul 20, 2018 7:36 pm
				by pixym
				Am I missing something or just denoising does not work with Render Region ?
				Posted: Mon Jul 23, 2018 7:06 am
				by pixym
				I have an odd issue, Instances does not render ;-(
Has somebody noticed that ?
				Posted: Mon Jul 23, 2018 7:33 am
				by BorderLine
				pixym wrote:I have an odd issue, Instances does not render ;-(
No problem here !
