Page 8 of 8
Re: OctaneRender® for 3ds max® v4.00-XB3 - 6.01 [TEST]
Posted: Thu Jul 05, 2018 1:03 pm
by paride4331
Hi coilbook,
checking "receving shadow" and/or "shadow cast" in object proprierties, apply and rebuild scene.
Posted: Thu Jul 05, 2018 7:07 pm
by acc24ex
I'm getting this - see the eatean up balls, like a square selection is not rendered.. I disabled and enabled everything I could think off - sort of worked better just rendering on a single 980ti.. 1080ti as primary - but also that's not constant.. any ideas?
this is how it has to come out - balls with numbers
Posted: Fri Jul 06, 2018 7:29 am
by paride4331
Hi acc24ex,
could you confirm all works ok using 3.08?
Setting all "movable proxy" is your issue fixed?
If not, could you kindly share your file, in pm, please?
regards
Posted: Fri Jul 06, 2018 5:20 pm
by senorpablo
I'm getting similar clipping issues on animated parts.
Posted: Sat Jul 07, 2018 2:58 am
by coilbook
HI Paride,
do you know by any chance how to create laser similar to this video. We need it to scan the cave same way https://youtu.be/3jeUTcNucYY?t=9s
is it even possible with octane?
Thank you
Posted: Mon Jul 09, 2018 12:36 pm
by paride4331
coilbook wrote:HI Paride,
Thank you
Hi coilbook,
maybe something like that, adjusting as you need.
Posted: Mon Jul 09, 2018 6:32 pm
by coilbook
Thank you
Hi coilbook,
Thank you looks great
