Page 8 of 13
Re: OctaneRender for Carrara 3.06.00.33[Stable]
Posted: Tue Aug 08, 2017 8:12 pm
by orion_uk
protovu wrote:Ok then.......its me!
Wonder what to check.
Could be, the squirrel in my computer needs feeding.
Maybe Simon will suggest a reload of the plugin?
Thank you again for testing. So good to know there are other CarraraOctaners out there.
Best,
Rick
No problem bud, maybe someone else or Sighman will chip in at some point? Not sure who is around these days/not looked yet lol. But do give me a shout any time if you dont find what you need here..like i say, IF i can help i will ;)
Posted: Tue Aug 08, 2017 9:43 pm
by protovu
Hi Orion,
Just did a simple test file that did, in fact, work. (Sphere moving in an HDRI scene)
Could be that the files I am trying to use are simply too complicated. I believe that I gave them ample time to load.
Will try again later and give a shout if anything comes of it.
Best,
Rick
Re: OctaneRender for Carrara 3.06.04.35[Stable]
Posted: Sun Aug 20, 2017 6:32 am
by Sighman
New update posted to this thread.
Uses latest Octane SDK and fixes a performance issue with LiveDB.
LDB crash
Posted: Fri Sep 08, 2017 8:16 pm
by protovu
Hi Simon,
I am able to duplicate a Carrara/LDB crash by simply scrolling down within the Cloth category. Haven't noticed crash yet in other categories, but duplicated 3 crashes in different files
searching Cloth.
Rick
Re: LDB crash
Posted: Fri Sep 08, 2017 8:57 pm
by Sighman
protovu wrote:Hi Simon,
searching Cloth.
Rick
Thanks for the report. I'll look into it. In the mean time, I enabled livedb in the local Db tab. You can try to download materials from there.
Posted: Fri Sep 15, 2017 11:29 pm
by protovu
Hi Simon,
On the LDB, today, getting the following message when scrolling down:
"Buffer size is not sufficient".
And, of course, not able to scroll down.
Local DB lets me view, but not download into Carrara.
Rick
addendum......just crashed....But on Carrara reload, now able to scroll down and select in LDB....
.almost: it seems like trying to view the very last, or bottom most Materials, stimulates a crash.
Posted: Sun Sep 17, 2017 4:09 am
by Sighman
Did you select import from local db?
Posted: Sun Sep 17, 2017 10:17 pm
by protovu
Right-click / import seems to work.
I don't know how I missed that.
Thanks. Now I have a new, fast LDB access.
Re: OctaneRender for Carrara 3.06.04.35[Stable] - shadow control
Posted: Sun Sep 17, 2017 10:41 pm
by protovu
Hi Simon,
I am having some problems with turning off shadows using the Octane Object Layer.
In particular, I would like to use an Octane enabled Spot light in my scene. Really like the controls you have enabled with the Spot.
Both the Spot and the Bulb are showing shadows, despite using the OOL modifier.
Rick
Posted: Mon Sep 18, 2017 1:23 am
by Sighman
Are you setting the object layer on the object casting the shadow? Setting it on the light will have no effect.
