Page 8 of 13
Re: OctaneRender 3 for Poser (Windows/OSX) [TEST and STABLE]
Posted: Sat Mar 25, 2017 10:07 pm
by Erick
face_off wrote:Following is a pre-release of the plugin compiled with Octane 3.06 TEST 4, which will hopefully resolve the issues people have had with Normal maps in previous Octane 3.06 releases.
3.6.3.82 pre-release
- Compiled with Octane 3.06 TEST 4
- Fixed issue where the Scatter mesh type was not working. If you change a figure/prop from Scatter or Proxy or Mesh, the scene will refresh if the Viewport is open
https://render.otoy.com/customerdownloa ... _Win64.exe
Could it be, that it's still broken?
I couldn't get it to work, atm. The scattered mesh did not appear.
I used Posers hi-res square as the mesh to be scattered over the ground plane.
After switching back from Node Type "Scatter" to "Mesh" (with the mentioned refresh of the Viewport) the mesh (hi-res square) showed up again.
Posted: Sun Mar 26, 2017 8:45 am
by Erick
I have to revise my post from above.
By creating a new transform file, scattering works well and as expected.
It's just that previous generated (in older versions generated) transform files do not work properly.
Posted: Tue Mar 28, 2017 6:11 pm
by wimvdb
I have been working a few days with this new version and it seems to work fine now. No more gpu crashes or other problems.
Good work!
Posted: Sat Apr 22, 2017 10:36 pm
by face_off
I have updated installer at the top of this thread with:
3.6.5.81 (23-Apr-2017)
- Compiled with Octane 3.06. See viewtopic.php?f=24&t=60014 for details
- Added status window to show the progress when the plugin is loading the camera animation track into Octane when the Camera Motion Blur checkbox is ticked
Posted: Sun Apr 23, 2017 4:00 am
by RGUS
face_off wrote:I have updated installer at the top of this thread with:
Thanks Paul, but why is the download file called "OctaneRender_for_Poser_3_4_4_79_Win64"... have you run out of numbers and have to reuse earlier ones?
Posted: Sun Apr 23, 2017 5:01 am
by face_off
Thanks for reporting this problem. I have put the correct filename in now. Pls re-download the installer.
Posted: Sun Apr 23, 2017 1:27 pm
by Erick
New version!
Yay, thanks Paul :D
Posted: Sun Apr 23, 2017 10:25 pm
by wimvdb
Thanks Paul!
Posted: Wed Apr 26, 2017 2:09 pm
by xorex65
Thanks for the update Paul ! :D
Posted: Sat Jun 10, 2017 8:52 pm
by OneShotos
I noticed that the latest OSX version of 3.6.5.81 has Subscription in the file name. The Previous version do not. Name mistake or is this the Subscription version?
