Page 8 of 9
Re: Skin Rendering
Posted: Thu Sep 12, 2013 3:17 am
by tonysculptor
I have a working hair shader now. It seems to work well. Here's a test render of some ZBrush Fibers. If anyone wants the hair material to test I will be adding it to the LiveDB under Materials>Misc and I will call it tonysculptorHair. If anyone does any good renders with it please post it or pm me.
Best
Re: Skin Rendering
Posted: Thu Sep 12, 2013 10:46 am
by gordonrobb
That looks great.
I will be starting something a sculpt soon and was thinking about hair. I'll have a look for sure. Did you get anywhere with an eye shader?
Also, is the worflow from ZB hair out to somethign that can be rendered in octane fairly straight forward?
Re: Skin Rendering
Posted: Thu Sep 12, 2013 2:53 pm
by xxdanbrowne
Zbrush fibermesh can be easily exported out as polygons. You just find the subtool that is the fibermesh and export that. Simple.
Re: Skin Rendering
Posted: Thu Sep 12, 2013 7:47 pm
by Garrick
Had you given any thought about making a zbrush to Octane video tutorial on rendering and shading a character. I would buy it if you did.
Re: Skin Rendering
Posted: Tue Sep 17, 2013 1:06 pm
by dawe
Really nice work! I love the skin and the sculpting to! I need to have a look at the sss material ;)
What I lack is some sort of sss node to be used as a mix map. as it is now its hard to do detailes in the back scattered areas
//Daniel
Re: Skin Rendering
Posted: Tue Sep 17, 2013 3:32 pm
by Witpapier
Hi there tony, I used your sss and intergrated it into what i have for poser and the plugin.. i realy like it, I have one problem tho, I tend to get red fireflies in the darker areas.. the node structure is pretty complicated and Im wondering if there is a spesific value you recomend me adjusting to get rid of that. :)... great work my friend, you really know your stuff.
Re: Skin Rendering
Posted: Fri Sep 20, 2013 1:02 am
by tonysculptor
I actually turn down the Hotpixel reduction value and just shoot a ton of rays at it. I'm glad it is working well for you.
Re: Skin Rendering
Posted: Fri Sep 20, 2013 8:25 pm
by Witpapier
tonysculptor wrote:I actually turn down the Hotpixel reduction value and just shoot a ton of rays at it. I'm glad it is working well for you.
I found the culprit to the firefly issue, under material one material mix material 2, medium [scattering] phase, scattering direction, must be set to 1.0 instead of 0.0, cant see the difference really but it eliminates the fireflies :)
Re: Skin Rendering
Posted: Tue Sep 24, 2013 4:17 am
by Tugpsx
@tonysculptor Thanks for the hair material, tried it here and it works great.
Having a bit of problem with the new skin material. I think I missed the input point for the textures as shown. Any help would be appreciated.
Testing tonyskin2
Testing tonyskin2
Re: Skin Rendering
Posted: Tue Sep 24, 2013 4:19 pm
by xxdanbrowne
Tugs,
Maybe you might need a bump map or a normal map or higher resolution geometry?
