Page 8 of 8
Re: Beta 0.5.9 (SDK 1.17 ) Updated on 08.06
Posted: Fri Jun 14, 2013 6:14 am
by bepeg4d
nehale wrote:Can someone please tell me how to get rid of this kind of noise, I'm rendering with PT and it seems to get more as time goes
which is the value of the caustic blur in the kernel settings?
if is set to 0, try with a value of 0.025 or above if you want to see some good caustic patterns, set to 1 if you want to complitely blur all the caustics.
for this kind of scene, the pmc kernel is the best, the caustic blur works the same as pt, at start it seems extremly more noisy, but if you wait a bit, it clears the scene more efficently
as you can see in the preview of your render, the noise is difficult to see, in fact the best trick for killing the fireflies is to render at double or quad the resolution needed and downscale the render in ps or gimp in post
ciao beppe
Posted: Fri Jun 14, 2013 9:49 am
by Method
Maybe it would be good to clear the error message on a computer not connected to the Internet. I know that I do not have a desktop computer connected to the Internet.
Posted: Fri Jun 14, 2013 5:11 pm
by aoktar
Posted: Fri Jun 14, 2013 6:27 pm
by 3Dfreak
aoktar wrote:3Dfreak wrote:RK-art wrote:Oops, yes, you are right.
Sorry and thanks.
I didn't overcopy the new files to the root directory.
Problem solved.
Glad it helped!! Happy rendering!
RJ
No longer no need to copying any libs files to c4d root directory. Plugin use any appropriate files from libs dir.
Strange, I just deleted those three files from the root directory. And now C4D R14 crashes on start up (while initializing the plugins) If I put the files back C4d R14 doesn't crash. I'm using Beta 0.6.4 (SDK 1.17)
