Page 7 of 8
Re: Cinema4D version 2021.1 RC3 (Current 2021) 04.10.2021
Posted: Mon Oct 04, 2021 6:46 am
by Ron
aoktar wrote:I've updated to RC3 with some fixes. Enjoy it!
WOW! You could handle the AVX2 options issue! This version seems to run as desired.
Thank you very much!
Ron
Re: Cinema4D version 2021.1-RC2(R3) (Current 2021) 04.10.2021
Posted: Tue Oct 05, 2021 7:25 am
by wrapthereal66
can't export denoise main passe ! i also read your comment for tick the use deonise pass as beauty, but don't work ether ! need fix please !!
Posted: Tue Oct 05, 2021 12:57 pm
by BCres
You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
Posted: Wed Oct 06, 2021 5:25 pm
by ndreimi
BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
I hope this can return as an easier way to add in the output settings. The AOV manager is great, but it was nice being able to easily toggle denoised beauty pass without needing to add a bunch of nodes.
Posted: Wed Oct 06, 2021 8:13 pm
by aoktar
ndreimi wrote:BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
The attachment Denoised beauty.jpg is no longer available
Can't be sure what's topic about that but did you try this new parameter? It will activate a denoised beauty pass(AOV). I had to add this as different way because there's not a denoised beauty AOV in core. It's an exception.
Posted: Wed Oct 06, 2021 8:21 pm
by BCres
Didn't see it. Wasn't there on last version. Didn't go looking for it. My mistake.
I'll try on my next render. Thanks!
Posted: Thu Oct 07, 2021 12:08 am
by ndreimi
aoktar wrote:ndreimi wrote:BCres wrote:You can get a denoised beauty with this setting (see pic). Some others on the forum helped me figure this out. Hope it helps.
Just what we needed. Trying now.
Posted: Thu Oct 07, 2021 12:09 pm
by wrapthereal66
again, background object make octane crash ! i don't know how i can help you with that ! but when i have a background with image sequence in it and when i start a live render, BOOM crash ! :/ really annoying
Posted: Thu Oct 07, 2021 4:10 pm
by aoktar
wrapthereal66 wrote:again, background object make octane crash ! i don't know how i can help you with that ! but when i have a background with image sequence in it and when i start a live render, BOOM crash ! :/ really annoying
You may kindly send a scene which causes this with detailed info. Because it's not crashing here
Posted: Fri Oct 08, 2021 11:30 am
by KeeWe
Since I usually only use stable releases: are there no render nodes for this version?
