Page 7 of 11
Re: Version 3.06-TEST4.1 (WORK IN PROGRESS BUILDS)
Posted: Wed Apr 05, 2017 11:49 am
by aoktar
moebius wrote:aoktar wrote: Like a joke! What are you using to freeze that soo long? Nothing should be longer than milliseconds
I found the reason: I had in the C4D preverences all Harddrives. Ctrl+E > Files > Texturepath
thanks aoktar
Great but what kind of paths was there? Plugin checks these paths to find the textures . But first It looks for project folder and its sub folders and next for these paths if cannot find in first lookups.
Posted: Wed Apr 05, 2017 3:48 pm
by Domenicozzo
Weird, this latest version doesn't see my cuda devices, I've never had this kind of problem before, I went straight from 3.05.3 to 3.06-4.1
I'll try to update my nvidia drivers, even if 353.30 should work. Thank for this update, Ahmet, looking forward to test it out.
Domenico
Posted: Wed Apr 05, 2017 8:45 pm
by aoktar
Domenicozzo wrote:Weird, this latest version doesn't see my cuda devices, I've never had this kind of problem before, I went straight from 3.05.3 to 3.06-4.1
Domenico
Pls check with more recent drivers. This version need cuda 8.0 and don't know but propably yours is not having that.
Posted: Wed Apr 05, 2017 9:20 pm
by Domenicozzo
Yes, the new drivers fixed the issue. I've tried some scenes and this version looks much faster when loading the geometry: excellent job, Ahmet!
Posted: Wed Apr 05, 2017 9:48 pm
by aoktar
Domenicozzo wrote:Yes, the new drivers fixed the issue. I've tried some scenes and this version looks much faster when loading the geometry: excellent job, Ahmet!
Thanks for first positive feedback
Posted: Wed Apr 05, 2017 9:50 pm
by aoktar
eyeonestudio wrote:Alt Gesture - Insert Still Buggy...
The attachment ff.gif is no longer available
what's happening with option?
Posted: Thu Apr 06, 2017 11:40 am
by JavierVerdugo
Hello Aoktar
I have downloaded all the sample scenes, but I don't see any example about triplanar node, I just try to find any information in the manuals, but there is none. I would like to know if you can share an example about triplanar, because I can't figure out how to use it.
Posted: Thu Apr 06, 2017 11:45 am
by aoktar
JavierVerdugo wrote:Hello Aoktar
It's a node which comes from core. You can check standalone topics. It's same.
Posted: Thu Apr 06, 2017 4:52 pm
by Frez121212
Getting an "invalid version" error on the network preferences even though both computers are running the same daemon version. (both have same standalone and plugin and i uninstalled the old daemon on both and installed the one from this test version on both)
Posted: Thu Apr 06, 2017 5:47 pm
by aoktar
Frez121212 wrote:Getting an "invalid version" error on the network preferences even though both computers are running the same daemon version. (both have same standalone and plugin and i uninstalled the old daemon on both and installed the one from this test version on both)
Slave should have same versions as plugin. Invalid version means that not equal versions on both side
