Page 7 of 11
Re: Version 2.22.2 - TEST3 - Updated on 03.04.15
Posted: Sun Apr 12, 2015 1:07 pm
by aoktar
Hi guys,
i'm very glad to see some MAXON presentations in NAB2015 which contains the Octane. It's here,
www.c4dlive.com for someone who wishes to watch.
Posted: Sun Apr 12, 2015 1:09 pm
by momade
aoktar wrote:momade wrote:ok. any chance that stoping render on compiling will be changed in a future stand-alone?
when using high-computation stuff like massive discplacement or motion blur with 32 time samplings per frame or super high poly trees instanced 100.000 times, stopping the render takes 20-30 seconds. if passes are enabled even longer. any way to speed this up?
I can ask for a way to interrupt, but i suppose that's not easy to implement. Personally, i prefer to have a faster compilation on geometries. This would be a big gain for each plugins.
i agree.
Posted: Sun Apr 12, 2015 6:59 pm
by momade
having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
Posted: Mon Apr 13, 2015 9:16 am
by pxlntwrk
momade wrote:having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
i'm not use 2 c4d instances , but sometimes i have stranges horizontales stripes in picture viewer (never happened like this before 2.2 ), its like 2 renders are mixed.
i ll try to post a screenshot...
anyway i ve just updated from 2.14 to 2.22.2 ,i know i come after the "battle", but it is normal that the f-stop and aperture sliders are sync and move both together?
Posted: Mon Apr 13, 2015 9:34 am
by aoktar
pxlntwrk wrote:momade wrote:having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
This glitch was here in 2.21 or 2.22 early versions. Have you tryed with 2.22.2 test3?
Posted: Mon Apr 13, 2015 9:39 am
by pxlntwrk
yes i've just updated from 2.14 to 2.22.2test3 , i've not use earlier since 2.14.
And for the aperture and f-stop sliders sync ?
Posted: Mon Apr 13, 2015 9:42 am
by aoktar
pxlntwrk wrote:Hi,
hmm, interesting. We don't see the glitches anymore. Can you post a screen shot?
And, yes both sliders are going together as in last Standalone.
Posted: Mon Apr 13, 2015 9:57 am
by pxlntwrk
Thanks for speedy answers...
i ll try to post a screen ..
Posted: Mon Apr 13, 2015 10:08 am
by pxlntwrk
Here, kind of glitches i have sometimes in PV since i have updated from 2.14 to 2.22.2 t3 ( never happened like this before )
Posted: Mon Apr 13, 2015 10:35 am
by abstrax
pxlntwrk wrote:Here, kind of glitches i have sometimes in PV since i have updated from 2.14 to 2.22.2 t3 ( never happened like this before )
Does this also happen, if you disable network rendering?
