Page 7 of 9
Re: Octane 2.0 Object Motion Blur and some other features
Posted: Thu Apr 03, 2014 9:46 pm
by gabrielefx
all this stuff is ready yet
the truck animation is a good example...
please Karba do some tests with dynamics applied to hair, I'm curious.
Posted: Fri Apr 04, 2014 12:20 am
by Rikk The Gaijin
gabrielefx wrote:please Karba do some tests with dynamics applied to hair, I'm curious.
Yep, I'm very curious about it too...
Posted: Fri Apr 04, 2014 9:22 am
by darkline
Amazing work. Good to know these features are already in a working 3DSMax beta
Was this direct lighting or PT?
Posted: Fri Apr 04, 2014 10:28 pm
by Seekerfinder
Wow, stunning!!
QUESTION:
For the random instance colouring, will we pick a range? Looks like you chose white & black there. How will this work?
Cheers,
Seeker
Posted: Sun Apr 06, 2014 2:46 pm
by MistAjuliax
Karba wrote:grimm wrote:Does the displacement use on-board tessellation? Very impressive!
No, it doesn't
Hi Karba,
as usual you achieve a great work, and i wonder how does the displacement work ?
Does it work like traditional grayscale displacement mapping that encodes the difference between the high-resolution model and the low-resolution model, using the low-res model's UV coordinates or like Vector displacement that uses a similar process, except it also uses the high-res model's UV coordinates, creating a correspondence between the two UVs ???
Posted: Sun Apr 06, 2014 4:42 pm
by merid888
ohhhh, impresionante, no tengo palabras, solo esperar la nueva versión 2.0 !!!
Posted: Sun Apr 06, 2014 4:47 pm
by seth
If I had to guess I would say it uses something similar to vrays 2d displacement.
Posted: Mon Apr 07, 2014 1:41 pm
by ROUBAL
Great demo ! Hey Karba, is the driver of the truck safe ? I noticed that there are no visible air brake tubes between the tractor and the trailer !
Hmm, forget : I think that there is no driver as well !
Posted: Mon Apr 07, 2014 3:23 pm
by kavorka
Must be one of the google cars that are driven by robots.
Posted: Mon Apr 07, 2014 4:41 pm
by matej
Hey, really impressive!!
Q: will the hair strand primitive be defined inside the .ocs too, or it will be just a Alembic thing?
