Page 7 of 11
Re: OctaneRender® for 3ds max® v1.0 beta 3.01[Test]
Posted: Mon Sep 24, 2012 10:14 am
by gabrielefx
areafilm wrote:gabrielefx wrote:
...the new 3.01 is slower than the 3.00c.
If you try your scene in Standalone version.. it's more fast and has more quality render.. try.. I don't know because.. Is it not possible use 3DSmax 2013 with standalone throught export plugin?
Having done more tests I can say that the 3.01 renders better than the 3.00.
In 3ds Max if we copy-->instance many copies of the same objects we get instances...
In theory making flat all instances we will get better performances, this is valid for scenes with few objects.
Is not possible to have a kernel that disables instances. We requested this feature for one year...
(instances)
Then, as Marcus said in another post, all the new Octane features will slow down a little bit the performances but we get more features.
Regarding quality, for example caustics, light distribution, shadows, I don't think that exist differences between Octane standalone and Octane for Max. The quality is the same and recognizable in every render posted in the Gallery.
Probably, for the fact that in Max we have more realtime controls over all parameters, we get slight lower speed and much noise (because the speed)
Why export from Max to Octane standalone? Imagine a complex scene with characters animations, instanced geometries, dynamics, keyframed shaders...
Posted: Mon Sep 24, 2012 12:00 pm
by cgp
Karba wrote:cgp wrote:Karba wrote:
Is it just black screen, or checker?
Checker
What GPU do you use.
Do you use this 3.01 plugin version?
quadro 5000.
yes, it atarted hapennin after upgrading to 3.01 in max 2012.
Posted: Mon Sep 24, 2012 12:21 pm
by tonycho
Hi Karba
please check
when I download livedb material (veludo (velvet) from Elvissuperstar007)
the falloff parameter is missing
I am using max 2013
Posted: Mon Sep 24, 2012 3:02 pm
by nildoe
I Just installed 3.01, and i also have a problem with this version, only checker appears... Using
3dsmax 2011 64Bits.
Nildo
Posted: Mon Sep 24, 2012 4:29 pm
by suvakas
Mix material is not working.
2nd material always renders white.
Suv
Posted: Mon Sep 24, 2012 5:27 pm
by boris
hey karba
tnx for the release.
any news regarding kepler cards? 4 gtx 680 are idling here....
cheers
boris
Posted: Mon Sep 24, 2012 7:56 pm
by Karba
nildoe wrote:I Just installed 3.01, and i also have a problem with this version, only checker appears... Using
3dsmax 2011 64Bits.
Nildo
Do you use old GPU 2xx? It isn't supported in this version.
Posted: Mon Sep 24, 2012 8:01 pm
by Karba
boris wrote:hey karba
cheers
boris
This version will work with Kepler. (20% slower then it should)
Posted: Mon Sep 24, 2012 8:02 pm
by Karba
suvakas wrote:Mix material is not working.
Suv
It works.
Have you set any material to 2nd slot?
Posted: Mon Sep 24, 2012 8:03 pm
by Karba
tonycho wrote:Hi Karba
please check
I am using max 2013
I will fix that.
