Page 59 of 63
Re: OctaneRender 3 for Modo [TEST and STABLE]
Posted: Thu Sep 20, 2018 10:51 am
by v1adut
Hi Paul, amazing work wih this new AI tools.
Can I ask you if you can make by default a button near the select viewport dropdown menu to toggle ai beauty/beauty render passes ?
Regards,
Vlad
Posted: Thu Sep 20, 2018 1:46 pm
by marcus1070
face_off wrote:
I'm doing my first tests, and I have a question: is it normal that AI Light and Denoiser slow down renders instead of speed them up?
This sounds like a non-plugin issue, so suggest you test in Octane Standalone and report to OTOY in the Octane 4.00 Standalone release thread if needed.
Hi Paul!.. i got an issue with this test octane 4 build.. denoiser dont work with hd renders.. just on preview... but in standalone goes ok...
in modo plugin, when denoise pass runs, goes infinite and slow down everything..
If you can provide an exact set of steps for me to follows to reproduce this issue, I will investigate further.
I think it's a free memory amount issue.. on standalone, denoising runs ok, but with a long calculation time, the plugin takes more time or even longer...
"PS: i'm using hdmi audio, and some noises go on when i run anything that uses gpus, and there a diference between noises in modo plugin and octane"
Posted: Thu Sep 20, 2018 7:07 pm
by MrFurious
v1adut wrote:Can I ask you if you can make by default a button near the select viewport dropdown menu to toggle ai beauty/beauty render passes ?
Regards,
Vlad
Vlad not sure if this is what you are referring to but it's possible do this in the form editor. I added beauty / denoised beauty toggle buttons in the octane toolbar.
Posted: Fri Sep 21, 2018 12:53 am
by face_off
I have updated the Octane 4.00 OSX build, and add a Linux build at the top of this thread.
Posted: Fri Sep 21, 2018 5:03 am
by face_off
I have updated the STABLE installers at the top of this thread with an Octane 3.08.3 build, which includes the relevant changes from 4.00.0.134.
Posted: Tue Oct 16, 2018 7:59 pm
by v1adut
Regards,
Vlad
Thank you very much , this is exactly what I was asking for.
Posted: Tue Oct 16, 2018 8:55 pm
by v1adut
@face_off
Paul can you insert this in the octane next build ?
Regards,
Vlad
Posted: Wed Oct 17, 2018 12:55 am
by face_off
I have updated the Octane 4 TEST builds at the top of this thread with:
4.00.0.135
- Compiled with Octane 4.00 RC6
- Added the option to save an animation to OCS/ORBX from the Export button on the toolbar (this was previously done via the octane.saveAnimation command)
- Added support for the OSL Projection
- EXPERIMENTAL: Added code to speed up transform changes on large meshes. This only applies to Mesh items with Live Geometry Update ON, and when the Render Cache if OFF.
- EXPERIMENTAL: Added support for OSL cameras
- Added support for the OSL UV Projection node
- Updated the Modo SDK from Modo901 to Modo10
Posted: Wed Oct 17, 2018 8:45 am
by MrFurious
Thanks Paul.
I'm getting a crash on launch with the latest test build.
Posted: Wed Oct 17, 2018 11:05 am
by face_off
Have you tried deleting your modo .CFG file?
