Page 53 of 62
Re: OCTANE BENCHMARK: Submit performance scores for your rig!
Posted: Wed Dec 17, 2014 6:56 pm
by Seekerfinder
smicha wrote:DL, coherent ratio 1, path term power 1, octane 2.14
GPUS OC: 1228mhz on core, 7000 mem
227.89 ms/s
temps 41-44C, water temp 35C
Smicha,
You are probably breaking some law now... That is insane. Did I miss you PT score or have you not posted it?
Seeker
Posted: Wed Dec 17, 2014 7:07 pm
by smicha
PT: 71.92 ms/s (same settings as for DL)
Posted: Wed Dec 17, 2014 7:28 pm
by Seekerfinder
smicha wrote:PT: 71.92 ms/s (same settings as for DL)
Very impressive. But I just saw Bulwerk's scores. Sorry kid...
Posted: Wed Dec 17, 2014 7:29 pm
by rappet
wow, that is something.. love to see those numbers.
Smicha, Change your name into 'Smashing!!!!' and then do not forget the exclamation marks ;)
Posted: Wed Dec 17, 2014 7:38 pm
by smicha
Thank you!
I am not sure but Bulwerk has 23k cuda cores in 8 gpus and scores 76ms/s, me only 9.6k in 4gpus ;)
Posted: Wed Dec 17, 2014 7:40 pm
by smicha
8-)
Posted: Wed Dec 17, 2014 7:49 pm
by Seekerfinder
smicha wrote:Thank you!
Yes, the ratio is completely out. Why is that? Are you overclocking?
Seeker
Posted: Wed Dec 17, 2014 7:53 pm
by smicha
OC is mild on stock 1.16 volts 1228 mhz on core.
Posted: Wed Dec 17, 2014 8:03 pm
by Seekerfinder
smicha wrote:OC is mild on stock 1.16 volts 1228 mhz on core.
Then the narrow difference between your hardware setups does not make sense. If Octane scales linearly, there should be at least 100% difference between your rigs, not 4%... Any other thoughts on why this could be?
Seeker
Posted: Wed Dec 17, 2014 8:08 pm
by smicha
I set path term power to 1 - this may be the reason.
