Page 6 of 10
Re: Version 4 - XB3-R1 (Experimental)
Posted: Wed Jul 04, 2018 9:15 pm
by cyartist
Hi Aoktar
Could you upload the library for r16?
Posted: Thu Jul 05, 2018 11:34 pm
by NC17z
pxlntwrk wrote:
NC17z wrote:Can anyone explain how to just export the Beauty Pass with the Ai Denoiser applied. Animated Sequence. A .tiff not Layered. I just want one image not a layered image.
Thank you in advance for any assistance in this matter,
Lenny
Thank you PXLNTWRK! I really appreciate it...
Lenny
Posted: Fri Jul 06, 2018 12:22 am
by aoktar
cyartist wrote:Hi Aoktar
I cannot for current build. I'll do it on next builds, sorry!
Posted: Sat Jul 07, 2018 12:21 pm
by lucioing
Lenny
Thank you PXLNTWRK! I really appreciate it too ! :D ;) ;) ;)
L.
Posted: Mon Jul 09, 2018 6:17 am
by franchus
Hi Guys!
first of all congrats! the plugin + Ai noise removal is magic!. I'm impressed.
I did render 700 frames of an extremely complex scene, but from there on I cannot render (it stalls c4d) I know this is an experimental release but I thought maybe the c4d bugreport might be useful. At first the scene crashed on the first frame, then I realized that if I put tonemap on one gpu and ai noise on the other it worked. I am on win 10 c4d r19 latest, 2 Nvidia gtx980 ti.
cheers! and keep it up, you're the best team in the world.
Posted: Tue Jul 10, 2018 12:16 pm
by slepy8
When I render beauty denoised, it behaves like it had "alpha channel" checkbox enabled.
But it isn't enabled.
Happens only in PV.
Tried lot's of settings - no luck.
Link to a scene file: https://1drv.ms/u/s!AoiD0SBLY9l-gfoVlztfr-as4VvQUA
Posted: Sat Jul 14, 2018 8:45 am
by VVG
tim_grove wrote:Anybody able to replicate those 700 Errors on the scene I shared?
on my simple scene
on the change of light parameters very often there is an error.
denoiser off
  • Started logging on 14.07.18 10:48:38
    OctaneRender 4.00 XB3 (4000008)
    CUDA error 700 on device 0: an illegal memory access was encountered
    -> kernel execution failed(kernel3)
    device 0: picking failed
    CUDA error 700 on device 1: an illegal memory access was encountered
    device 1: picking failed
    -> failed to allocate device memory
Posted: Wed Jul 18, 2018 4:28 pm
by fatrobotsneedlove
slepy8 wrote:When I render beauty denoised, it behaves like it had "alpha channel" checkbox enabled.
Happens only in PV.
This happens for me also.
Will there be a ‘use denoised as beauty’ checkbox at some point like in standalone?
Posted: Thu Jul 19, 2018 10:47 am
by NC17z
Happens only in PV.
I noticed that as well, it has something to do with the environment. I loose my background... I use Greyscalegorilla's HDRI Plugin.
Posted: Tue Jul 24, 2018 10:00 am
by wehuber
Hi guys,
I am experiencing a very strange error with this release. Whenever I try to render only the denoised beauty pass C4D renders exactly 3 frames and crashes when it starts frame 4. In contrast, if I disable AI denoiser and render it the standard way C4D renders 3 frames and stops at frame 4 without crashing. This keeps happening in various scenes
I am using the latest R19 build with 3 GTX 970 on Win7 and also tried different NVIDIA drivers already (removed them properly using the DDU tool). I attached the output of my Octane error log, maybe it makes sense to you.
Hope you guys can solve this issue since the denoiser works like a charm and would be of good use right now...
Cheers
