Re: 1080 Ti and Octane
Posted: Sat Apr 01, 2017 8:02 am
I just upgraded my PC with two gtx 1080 ti Founders from Asus ....this is the bench ( they work at about 1800 Mhz and 82 C stock settings)
Hi Guys,rappet wrote:Hi guys,
Later I will post my findings for perfromance difference in my own projects as a workflow comparising,
because for me that is all that counts in practical way.
cheers,
The OctaneBench is 2.17 and does not support Pascal, right?glimpse wrote:Thanks for information Rappet![]()
I though it [1080Ti] should behave as TitanZ. Curious why there is difference on some scenes though, but I guess that was due to architectural differences.
If You happen to run OctanBench, could You please post those print-screen of that with final results + that extra table that pops in the end? (curious TitanZ vs 1080ti)
Yeah, 2.17 does not support Pascal based cards, but You can run this one:rappet wrote: The OctaneBench is 2.17 and does not support Pascal, right?
or do you mean another OctanBench...? I have read about an unofficial or 'cracked' OctaneBench somewhere around this forum.
Hi glimpse,glimpse wrote:Yeah, 2.17 does not support Pascal based cards, but You can run this one:rappet wrote: The OctaneBench is 2.17 and does not support Pascal, right?
viewtopic.php?f=9&t=56108&p=289082&hilit=1080#p287699
would be very thankful if You could Run TitanZ; 1080TI & then both =)
strange thing, v3 behaves a bit different & thus when I'm running with pair of cards I always get lower than separately.
nice, thank You! ;) not sure if I posted this, but mentioned somewhere, that technically You should be able to get about 200 & in some cases even more if You would bump core clock +200 & memory +500. With curve adjusted or fan put in a fixed speed mode (70 to 100%), this card would still keep good temps. As far as I know there's not so much of possibilities to push TitanZ on air =)rappet wrote: Hi glimpse,
TitanZ: 191.45 / 1080Ti: 165.45
1080 Ti ran at 1822 mhz, no overclock, 74 Celsius.
The precious TitanZ is still king with +15% :lol:
cheers,
mmm.... ? with this OC it does not come close to the 191 of the TitanZ in this Benchmarkglimpse wrote: So yeah, TZ might still seem faster on paper, however in reality with some tweaks these are more or less the same in terms of performance
