Page 6 of 9
Re: OctaneRender® for 3ds max® v2.24.2 - 2.16 [STABLE]
Posted: Thu Jan 21, 2016 1:42 pm
by remKa
Hello,
I also have trouble with the gamma of .EXR files.
When I save from the Render Output (1), with gamma set to "automatic (recommended)", my file will have gamma 2,2 applied twice.
When I save manualy from the MAX Buffer (2), with gamma set to "automatic (recommended)" , my file has the correct gamma.
That may be a 3DS Max issue, it's very frustrating while saving multiple render passes :)
Posted: Thu Jan 21, 2016 4:48 pm
by Goldisart
Jimm thank you very much for simple and intuitive setting of the Imager !!!!
Posted: Thu Jan 21, 2016 4:58 pm
by JimStar
remKa
I will check it, thank you for report. Looks like 3ds Max bug, 'cause in both cases 3ds Max saves the same its own internal image buffer holding the same data loaded by Octane plugin after rendering the image. Looks like in this case 3ds Max does not respect the gamma set in internal buffer info and assumes the buffer is always in 1.0 gamma. So I think the simple workaround here - just have 1.0 gamma in Octane imager if you save HDR image.
Posted: Thu Jan 21, 2016 6:38 pm
by Notiusweb
Just wanted to report, as I have been following this thread, that in using the Alpha 3 standalone, and then exporting a 'Tonemapped' EXR, it went over to Photoshop as 'brighter'.
I had to lower the gamma in PS to get it to match Octane's display. But, If I exported an 'Untonemapped' EXR, it came over not requiring the gamma adjustment.
I don't know if this is related or not, as I know this plugin is not at Aplha 3.0...but just thought I'd share. I can ask about it it in the main build forum.
Peace.
Posted: Sun Jan 24, 2016 1:32 pm
by kevinshane
Hi Jim, could u please add normal map a "invert Y" option(or I should say -Y option ?) for converting the DX normal to openGL normal map?? cuz I find that octane is reading the opengl normal map right?? but most of the other ungine using dx normal map, I have to prepare two format normal map to suit for unreal and octane! could u please make it happen?? thanks
oh btw, I have a maya license but ever since I bought the maya license by mistake(well...it's my fault,and i know that, i want to buy more max licenses but I click the wrong button and buy a maya license..lol...)..so my question,since u are developing both max and maya,so could u please transfer my maya to a max license??(my maya has 2.x license but eating dirt since 1.2 when maya out...I've never use the maya...) :oops: could u do that for me ?
Shane
Posted: Mon Jan 25, 2016 10:23 am
by Goldisart
when use tone mapping stops working alpha channel ( enable gamma/lut correction - ON (2.2))
Posted: Mon Jan 25, 2016 10:50 am
by Elvissuperstar007
bug MB
direct working
beauty does not work
Posted: Thu Jan 28, 2016 3:39 pm
by darkline
Hi Jim - have you had any thoughts on the problem I posted in the last release thread? :
Ive got a bit of a problem with animating octane camera properties :
I have many shots that need 3D tracking/solving for visual fx work and rendered with octane. So my workflow is I solve using Syntheyes and then export to a maxscript. In 3DSmax I now have my scene markers and camera movement and it's all good. The problem arises when I needed to animate the focus depth of the camera (as the camera moves in) - you can't animate any of the octane settings unless you use an octane camera. The camera in my scene is a standard max camera (as would be exported from all 3D tracking solutions), and there's no way to turn it into an octane one in 3dsmax.
My workaround has been to create an octane camera, switch from the standard max camera to perspective view, match octane cam from current view and then link the octane camera to the max camera. The problem here is there is drift due to octane cam not having a target point, when the max camera does. So it becomes a very difficult process to use octane cameras for 3D tracked shots with a moving camera.
Is there any way you could either a) have an option to switch max camera to octane cam (retaining all it's animtion exactly) or b) have the octane camera controls available to animate using a standard max camera too?
thanks
Posted: Thu Jan 28, 2016 4:14 pm
by boris
darkline wrote:Hi Jim - have you had any thoughts on the problem I posted in the last release thread? :
thanks
can't you link octane camera target to max camera target and octane camera to max camera? i thought i have done this sometime in the past.
Posted: Fri Jan 29, 2016 2:38 pm
by oguzbir
New bug report
Re: Appling symmetry to object flips textures in a wrong way.
viewtopic.php?f=81&t=52450
