Page 6 of 28
Re: New version 1.09a (based on SDK 1.24) ****PREVIEW****
Posted: Fri Jan 10, 2014 6:27 pm
by melekrel
all i see is what was there before. update mesh and mesh no... do i need to update the standalone? i dont think thats it but i updated the sdk and the lib 150 files. im working on c4d r15.
Posted: Fri Jan 10, 2014 6:32 pm
by aoktar
melekrel wrote:all i see is what was there before. update mesh and mesh no... do i need to update the standalone? i dont think thats it but i updated the sdk and the lib 150 files. im working on c4d r15.
No need to update standalone. old version of plugin has that controls. Did you removed all Octane files from c4dOctane and main C4D dir. before copying?
I'm uploading 1.10 soon
Re: New version 1.10 (based on SDK 1.25) ****FOR TESTING****
Posted: Fri Jan 10, 2014 7:45 pm
by melekrel
ya so first i took out the old sdk into a temp folder. then i removed the old lib folder and put it into a temp folder. then put new sdk in and new lib 150 folder in. that was all i did. would the old lib 32 folder effect it in anyway should i remove that?
Posted: Fri Jan 10, 2014 8:15 pm
by aoktar
Melekrel, i wrote and showed on first page of this thread that how should be the files.
Posted: Fri Jan 10, 2014 8:26 pm
by melekrel
Thanks for your help.. i re downloaded it and its working great. your awsome and the plugin in really coming together.
Re: New version 1.09b (based on SDK 1.24) ****FOR TESTING****
Posted: Sat Jan 11, 2014 3:14 pm
by Pixelkingdom
Hi Aoktar,
im working currently an on project where i use a lot of normalmaps. I try RC1 and this beta, both version have these problems.
But Octane seems to use only till 10 normalmaps at the same time. If more than 10 maps inside the scene octane cant render it! Can u fix this bug.
http://www.directupload.net/file/d/3499 ... 9u_jpg.htm
http://www.directupload.net/file/d/3499 ... bp_jpg.htm
LG
Posted: Sat Jan 11, 2014 4:38 pm
by aoktar
Didn`t check but, i`m sure it`s a texture limitation your gpu. Please don`t think everything is a bug
Posted: Sat Jan 11, 2014 4:46 pm
by Pixelkingdom
I have used only 22 textures - image textures. Thought Octane could handle 144 LDR RGBA textures.
Posted: Sat Jan 11, 2014 5:01 pm
by aoktar
Pixelkingdom wrote:I have used only 22 textures - image textures. Thought Octane could handle 144 LDR RGBA textures.
Need to check sizes and vram consumption. But plugin has not any limitation on any aspect, just works as a bridge
Re: New version 1.10 (based on SDK 1.27) ****FOR TESTING****
Posted: Sat Jan 18, 2014 2:50 am
by TBA3D_70
The new mac test plugin for version 1.27 produce a message at C4D startup (R15 newest).
--> "can“t load the octane plugin binary"
Best regards,
Thomas
