Page 6 of 10
Re: NEW : Preview of OctaneRender 1.5 Per object visibility
Posted: Mon Nov 25, 2013 6:25 pm
by ashurao
Hello,
This is great news. I'm looking forward to testing this new update.
With these new features, plugins will they still useful?
We just have to export with alembic file, from C4D for exemple, right?
Posted: Mon Nov 25, 2013 8:49 pm
by merid888
amazing, waiting for next reléase
thank you octanerender team !!
Posted: Mon Nov 25, 2013 9:24 pm
by Elvissuperstar007
DOUBLE-SIDED MATERIALS
Posted: Tue Nov 26, 2013 12:44 am
by RayTracey
gabrielefx wrote:very good!
gabrielefx wrote:is it possible to set on-off visibility in reflections?
i see the car reflected on the floor but invisibile, is it possible to do the inverse?
Visibility of reflections is not possible.
pixelrush wrote:Hmmm yeah, objects need to be made invisible in reflections too, otherwise very good.
You can make objects completely invisible using their general visibility.
suvakas wrote:Awesome!!!! Just awesome... thank you so much for this feature.
And when it's invisible for camera it doesn't generate alpha, right?
Suv
Thanks Suv, invisible objects shouldn't generate alpha.
bepeg4d wrote:great, well done, thanks for sharing, Sam
ciao beppe
Thanks Beppe
ashurao wrote:Hello,
This feature will be exposed through the API, so the plugins will have it as well. Alembic is just a file format to interchange animated scenes between plugins, plugins to standalone or plugins to cloud.
Posted: Wed Nov 27, 2013 8:19 am
by Andygraph3D
hmm ... but this new feature will give more speed to render ?
if i have many opacity map and esclude the cast shadow, the render will be more speed ?
Posted: Wed Nov 27, 2013 8:30 am
by gabrielefx
now is possible to create a dome with an HDR texture applied on it and use the sun.
The dome will not cast shadows and we will use hdrs+sun.
simple!
Posted: Wed Nov 27, 2013 9:08 am
by tegatwork
HDR + sun? What a great news, i'm very missing that feature...
Posted: Wed Nov 27, 2013 9:25 am
by Andygraph3D
ok hdr + sun but .. the hdr + sun work on all scene but if i dont want the cast shadow only one object ?
Posted: Wed Nov 27, 2013 9:53 pm
by Sighman
Andygraph3D wrote:ok hdr + sun but .. the hdr + sun work on all scene but if i dont want the cast shadow only one object ?
According to the initial post, the object that you don't want to have a shadow for must have its own 'object' ID. I don't know how object IDs are assigned but this will need to be a function of the OBJ exporter or plugin.
Posted: Mon Dec 02, 2013 11:39 am
by enricocerica
Sighman wrote:Andygraph3D wrote:ok hdr + sun but .. the hdr + sun work on all scene but if i dont want the cast shadow only one object ?
I think it simply means that the object should be exported individualy and imported in a dedicated mesh node.
