Page 42 of 55
Re: Which feature do you need the most?
Posted: Mon Mar 20, 2017 5:47 pm
by Notiusweb
I'm thinking this is a small one, but who knows...
Can there be option in the Background image dialogue button to allow the image to override an Alpha-only export?
This way the image will be intact in the final render.
Posted: Fri Mar 24, 2017 3:49 pm
by nuno1980
The water vapor (cloud, nebulosity, fog...) should have dispersion because we see halo (nebulosity very low opaced) but gases have (much) lower dispersion than liquid/solid.
Smoke, dust, brume... haven't dispersion due to the lack of humidity (= 100% dry),
Currently OR cannot render "halo"... But halo support for v3.1 or v4?
Posted: Fri Mar 24, 2017 10:12 pm
by Lewis
Hi!
Guys, can we get feature that Displacement node works with Projection node and with procedurals ?
Posted: Fri May 05, 2017 10:03 am
by Phantom107
What about the ability to draw a PNG background on top of the render view? Then it would be able to for example import an image that has the rule of third on it, that would help placing the cameras
Posted: Wed May 10, 2017 9:03 am
by Notiusweb
An ability to filter, by text, items in the Geometry Node list.
Give you a working list filtered by a text string, so you don't have to mouse up and down looking for a single item set amongst the whole entire mesh list.
Posted: Sat May 20, 2017 1:52 pm
by RealityFox
Simplified Skin shader. Something like what Renderman has, I learned how to make a decent skin shader but for newbies something simple and effective for skin would be great.
Posted: Sat May 20, 2017 2:27 pm
by rajib
Dear Octane team,
An easier way to position the sun in the daylight environment would be most welcomed. Something that doesn't need me trying to locate where in the world the scene is supposed to be located or modify and set so many sliders to just try and get the sun to be where I need it to be. Just 2 sets of control. One how high or low the sun is on the horizon, and another that controls the direction of the sun with regards to the camera which can be a slider with 0 to 360 as value.
E.g. Direction of sun slider - 0/360 would place the sun behind the camera, 90 on the left of the scene, 180 on the back of the scene, and 270 on the right of the scene. Height of sun slider - 0 to 100, 0 would place it at horizon, 100 at the top. The two values will position the sun with regards to the camera.
Can something like that be implemented as a separate option from what is provided today ? Users of Octane can use either one they prefer - location and time based lighting (current) or just control that actual sun position by setting just 2 sliders.
Rajib
Posted: Sat May 20, 2017 4:13 pm
by PolderAnimation
Cryptomatte would be very nice to have.
Posted: Wed May 24, 2017 11:30 am
by Notiusweb
Can you add a check box that will say "2X Speed Multiplier", or something to that effect? I know it is silly and may not do anything as it is just text with a check box next to it, but I'm thinking maybe the program will believe it does do something and give us twice the speed?
I know, I know....why not then "10X Speed Multiplier"....Well, I just don't want to tip the program off. Just thinking something subtle enough to make it sound plausible...
Posted: Fri May 26, 2017 2:24 am
by Notiusweb
How about "Extra Hot Pixel Removal"? For those stubborn hot pixels that still insist on being rendered no matter how much Hot Pixel removal you apply?
It would be nice to eliminate them!
