Page 5 of 6
Re: Beta 2 Crashes at startup
Posted: Thu Apr 15, 2010 9:20 am
by radiance
Hi guys,
These issues are driver or system/OS related.
There is'nt much we can do then offer you the same checklist as in this post.
Radiance
Posted: Fri Apr 16, 2010 9:12 am
by zemmuonne
what if octane worked before a reboot and stopped working after a reboot (rebooted 'cause octane crashed, leaving flickering pixels dust overall the monitor)? Nothing changed except adobe reader update :|
Posted: Fri Apr 16, 2010 9:19 am
by zemmuonne
now it works. I swear I didn't do anything except starting up dreamweaver and making some work. o_O;
Posted: Fri Apr 16, 2010 10:37 am
by atome451
Hi all,
Maybe a little solution in some cases.
I have tested a demo version in 64bits on another computer with Windows 7 64bits. Octane crashed all the time excepted the first time i tested it after installation with administrator privileges. Then i have tried to run it as administrator and it work fine now. If i remove administration privileges in compatibility tab of my link, it crashes again...
It's probably not the only solution for all problems but it works for me. ;)
Hope this will help someone.
Posted: Fri Apr 16, 2010 12:08 pm
by zemmuonne
atome451 wrote:Hi all,
Running it as admin did the trick. Wonder why it happened randomly tho'...
Posted: Fri Apr 16, 2010 2:26 pm
by metalliandy
Ok this is odd.
I just ran the program as normal and it crashed.
I then ran it in XP SP2 compatibility mode and it worked..i then turned off XP SP2 compatibility mode and now it works all the time.
That doesn't make much sense now does it?
If anyone has an idea of why this happened, please feel free to enlighten me...im confused :P
But anyway...now it works :D
Posted: Wed Apr 21, 2010 2:38 pm
by metalliandy
@Radiance
Can you see any reason why using XP compatibility mode fixes this problem?
It seems as long as XP compatibility mode is on for the initial startup of the program it will work perfectly (even if i uncheck it) until the next reboot of the pc.
Any ideas?
Posted: Wed Apr 21, 2010 3:42 pm
by radiance
metalliandy wrote:@Radiance
Any ideas?
i don't have a clue.
drivers is the only thing i can think about.
maybe try the driver sweeper tool and reinstall the latest drivers or something?
Radiance
Posted: Wed Apr 21, 2010 8:38 pm
by kubo
same problem here.
The thing is, when I first tested it I had a couple of this, but I had not installed the cuda drivers, later I tried with scene A, wich worked fine, althou it crashed a couple of times, now I'm trying it with an old scene, not too big of an interior rendering (actually the obj is the same size, about 29Mb), and it's crashing big time, it goes all the way to import the geometry, and as soon as I select the mesh it goes away without a friendly advice.
While I was writting I've updated the mesh, selecting only a few and exporting works, when i add the rest, it crashes
Don't know if ti helps, I'll keep on testing with this scene.
Posted: Wed Apr 21, 2010 9:08 pm
by radiance
you need to apply the registry fix here: http://www.refractivesoftware.com/forum ... f=21&t=824
also install the latest WHQL drivers for your OS/card from the nvidia site.
octane is very stable, so these issues are hardware/OS/driver related.
Radiance
