Page 5 of 5
Re: OctaneRender® for 3ds max® v2020.1.5 - 10.19
Posted: Mon Oct 26, 2020 3:16 pm
by paride4331
Hi Nick73,
It seems to work, could you share your issued scene?
Posted: Mon Oct 26, 2020 3:53 pm
by paride4331
nick73 wrote:Hi Paride,
Converting materials has been broken in 10.19. Previous release did convert normal map and I should only toggle it from bump node to normal. Now It's missing at all. I guess I preferred as it was before. Another thing, I believe the script should convert transparency map into transmission node with a gamma of 2.2. I am using this all the time with good results.
Thank You.
Hi Nick73,
yes, the normal/bump conversion is a know issue.
About vray trasparency map, it is the opacity map in Octane, not transmission.
Posted: Mon Oct 26, 2020 8:31 pm
by nick73
Thank You.
Hi Nick73,
Hi Paride,
My fault that was a standard material. I think Vray Translucency Map is Octane Transmission (at least this works good for me).
Kind Regards
Nick
Posted: Mon Oct 26, 2020 8:35 pm
by nick73
paride4331 wrote:Hi Nick73,
In this case the bug might be in the exporter...
Thank you!!
Posted: Tue Oct 27, 2020 10:13 am
by paride4331
Hi Nick73,
exporting to .orbx, SA gets the Mesh Uv projection active only; I guess it depends on SDK.
You could try using a composite material node.
Posted: Tue Nov 03, 2020 9:23 am
by samsue
Please improve it! Really...
Posted: Tue Nov 03, 2020 3:34 pm
by Elvissuperstar007
if you animate transparency in the material, then import it into the stand ORBX, the animation does not work
Posted: Wed Nov 04, 2020 5:00 am
by neonZorglub
Elvissuperstar007 wrote:if you animate transparency in the material, then import it into the stand ORBX, the animation does not work
Hi Elvis,
Do you mean the Opacity of an Octane material ?
It seems to works fine ; here is a sample with a Glossy material:
mtl_opac_anim.zip
(90.03 KiB) Downloaded 289 times
Note: the 'Animation' checkbox must be enabled in the Octane export dialog (and some start/end frame set..)
I hope that helps,
